Who's running a #6 in a single engine application
I am going to have my 540 with Whipple 5.0L upgraded over the winter, I am looking @ upgrading my Max Machine Worxs drive and going with a #6 drive. Is there anyone running this in a single engine cat, pros, cons, what should I expect, will I benifit by going this rout, will it be worth the upgrade, just waying my options, I thought about going with the IMCO SCX but I just don't think it would hold up...any input would be greatly appreciated
You may want to do some research on the new "indy" and the conrad.
The conrad is pretty much bullet proof. I read alot about the new Indy.. That will hold some big power as well and not rob alot of HP to use!! I heard $ for $ the indy and the conrad are much cheaper then the #6 for the complete set up.. Also the # 6 is not bullet proof either just a lot more reliable for big power and heavier hulls Did you consider and Arneson or a surface drive? Rik at Arneson can really hook you up too. #6 uses a lot of HP to run!!
Good luck and post what you do
"commander112" went from Bravo blues to a Number V drive (5, not a 6); on his Commander cat. (1300HP or something close to it)
It took a lot of dialing in and work. He had to move the engine forward & redo the transom, and a bunch of other stuff. When it was all done; he sold it for a stock powered 28AT.
Keep it stock (or mild) and go boating on the weekend;
or make it radical and go wrenching on the weekend.
