If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    Forum Regulator VIP Member Sydwayz's Avatar
    My Boats:
    37' Active Thunder AVH; 17' Speedliner Cat OB
    Join Date
    May 2001
    Quote Originally Posted by XX14 View Post
    Ok, so do I pump the heat exchanger, then drain the block on both sides and both exhaust manifolds, close the petcocks, and then pull rv anti-freeze through the drive?
    Yep, that's exactly what I do.
    Run it up to temp.
    Change the oil.
    Run it up to temp again.
    Pump and Drain all the freeze plugs-
    IIRC, there are 5 blue freeze plugs on each motor.
    1 on each side of block
    2 on SWP assembly
    1 on back of oil cooler (far aft-port side of motor)
    Run 3 gallons of AF through the motor.
    Shut down and pull fuel/water separator-
    Fill FW separator 1/2 full of 2-stroke oil & reinstall.
    Run 3 motor gallons of AF through the motor.
    Coat with WD-40
    That's it.
    As for your impeller, it is likely that it is damaged. The AF is slightly thicker than water and hence it will be harder to pull up the outdrive.
    BUT, I don't do mine with muffs. I HATE running on muffs. I installed T-fittings directly infront of my SWP so my garden hose injects water right infront of the impellor. When you turn the water hose on, it flushes from the SWP backwards out the drive.
    When you tun the engine on, it sucks the water directly into the SWP. No tape or muffs needed.
  2. #12
    Registered Bosco's Avatar
    My Boats:
    Avanti 1986
    Join Date
    Nov 2000
    Crystal River, FL
    x- mercury makes a nose cone water pick up you can plumb with a set of the typical ear muffs. eliminate any b.s with tape and worry and give the drive all the water it can stand.
    never run it without water you will cook the pump in seconds not minutes.
    winterization consists of removong all the raw water from heat exchanger and riser/manifold combo. these motors have blue drains which will eliminate all those freez concerns. the closed part of the system should be filled with anti-freeze.
    lastly, i fog with marvel mystery oil. run the motor to temp, and gradually introduce a spray into the air intake. trust me the motor will gobble it down and stall. thats all..............
    in the spring she will smoke on start up but clear up rapidly. put in new plugs and enjoy!
  3. #13
    My Boats:
    Join Date
    Jun 2009
    New Lenox IL
    Even the muff on the front wont suck up water thru mine. I have a seastrainer on my boat so it is simple to pop off the cap and run the hose inside it. Also, If you are in a freezing climate, dont forget to check the coolant in the closed cooling portion to make certain it is good for cold temps. Dont be afraid to splash some antifreeze in the bilge at the bilge pump in case there is any water inside it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
