Go Back   Offshoreonly.com > General Discussion > General Boating Discussion
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-20-2009, 01:19 AM   #11
Rob
Strip Poker 388's Avatar
Hustler 388
header looks tarnished? Sounds good
Strip Poker 388 is offline   Reply With Quote
Old 11-20-2009, 01:43 AM   #12
Chris
CB-BLR's Avatar
2009 Nordic Heat - 600sci - Whipple Stage X - SCX drive
Quote:
Good eyes...
The header got tarnished the first week I had the boat because of some cooling issues.
Chris
CB-BLR is offline   Reply With Quote
Sponsored Links
Old 11-20-2009, 03:20 AM   #13
WHYC / NIOC
Back4More's Avatar
42 Fountain/370 SeaRay
Stage II should get it to 740HP...
Saris Racing 800SC
Bmax/-2 IMCO's
Cryo Gear sets
IMCO Boxes
MitcherT
Livorsi
Back4More is offline   Reply With Quote
Old 11-20-2009, 08:36 AM   #14
ORIGINAL PIRATE
wellcrafted's Avatar
Velocity 2008 290 600 SCI Sea Ray 1989 Sorrento S-19 Starcraft 14 Dog Boat
Quote:
Originally Posted by CB-BLR View Post
The water re-route was to pull water off the main line right after the raw water pump, instead of off the power steering cooler in order to get cooler water to the innercooler, and thus make more and safer horsepower.
Chris
Chris
I have 29ft velocity with a 600 sci iam getting 80-82 on gps all stock.(same speed as yours before your mods.)
Questions
My oversized sea strainer has to outlets with one being plug right now, can i use the second outlet and run it to the innercooler versus adding another sea strainer / water pickup etc . Also to get to 700 hp all i have to do is have dustin reprogram ecu plug back in and go with seperate water line to innercooler .
no pulleys/cam or anything .
John
wellcrafted is offline   Reply With Quote
Old 11-20-2009, 09:02 AM   #15
Ridin Dirty
2010, Active Thunder, 37 Excess
Quote:
Originally Posted by wellcrafted View Post
Chris
Questions
John
You would have to pick the water up somewhere behind the sea pump. If you get it at the strainer there will be no pressure to force the water throught the intercooler.
Not sure about the pulley.
JeffC is offline   Reply With Quote
Old 11-20-2009, 09:07 AM   #16
Ridin Dirty
Here is a video of the 700hp pass on the Whipple dyno:
http://www.youtube.com/watch?v=6BTsMEudtCw
Chris
Thats cool as hell chris.. I watched some guys dyno a 350 race motor and they ran it up to 9800rpms and i thought that thing was going to explode..
So it made 700 with the reprogram and waterline upgrade?
Old 11-20-2009, 11:24 AM   #17
Chris
CB-BLR's Avatar
Correct... the motor made 700hp with only the PCM re-program & water re-route. No other mods of any kind.
You do not want to pull the water off the sea-strainer... Dustin has the correct parts in his kits to re-route the innercooler water... very easy mods.
Chris
Old 11-20-2009, 04:30 PM   #18
Chris
CB-BLR's Avatar
The new numbers are in for the Stage II upgrade for the 600sci:
752hp at 5850rpm !
This is what you get with just a PCM re-program, a water re-route, and a smaller pulley.
Dustin rocks!
Old 11-20-2009, 04:59 PM   #19
Ridin Dirty
752hp at 5850rpm !
Dustin rocks!
So what are you going run with? Stage one or two.
Old 11-20-2009, 05:41 PM   #20
Chris
CB-BLR's Avatar
I will be running stage IV+
I explained the stages in my first post.
Chris
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
