| OSO Sponsor |
| OSO Sponsor |
11-19-2009, 11:04 PM
06 37 Active Thunder (for sale)
Where can I buy 1" airex??? Only need like a 2' X 2' piece...
Anybody????
11-20-2009, 07:09 AM
Charter Member #232
1979 Formula 302
Try Composite One in RI. Not sure if they will sell you a small piece or not. You could try calling up Outer Limits and other builders in the area and see if they can cut you a piece.
God is my Co-Pilot..... but I hit a mountain and had to eat him.
11-20-2009, 08:26 AM
coolrunning racing
built myself 1994
You could also try Jamestown Distributor's. They might. Oh they are in RI as well.
11-20-2009, 08:28 AM
thanks guys, ill give them a try.....
11-20-2009, 08:53 AM
no luck, they'll only sell whole sheets, anybody else???
11-20-2009, 12:13 PM
Charter Member #232
1979 Formula 302
How much is a sheet?
11-20-2009, 01:12 PM
$500 or something crazy
11-20-2009, 02:18 PM
Neno the mind boggler
Batboat, 38 Donzi ZX, 16 Sidewinder, 10' Zodiac and a ScarabIII
what do you need it for? i have some pieces of scored 3/4 that are at least 2'x2'
08 OPA High Points Champion
11-20-2009, 02:25 PM
i need it to close off a section of my door to the cabin. my boat used to be a race boat and when they cut my door opening they cut it to close to the gauge panel, and it started to crack from the top of the door towards the gauge panel, because it is only like a 2 inch strip. so I am going to close back off the horizontal part of my opening, re-glass all the old gauge panel openings that arent being used anymore, and behind the dash, the whole width of the dash put two more layers of glass......im just trying to stiffen up that part of the boat
11-20-2009, 02:40 PM
Charter Member #232
1979 Formula 302
Could you use lighter density foam? Or plywood?
