Whipple 700sci Mods
#31
Several people have asked this and numerous have answered. I'm sure they will post but the short answer I've read is some have failed (2 i know of) but most have not(more than 12). I'd say the golden rule is if u abuse anything it will eventually break. Use this extra power to blast past someone then come back to your normal cruising speeds once you have proven your faster!!
#32
#38
Chris
Dustin has been gone this last week.
I was texting him on Tuesday, and he said he would have pictures for me of the new spark arrestor on Monday, and that the innercooler fittings should be done the first part of the week.
These oversized innercooler water fittings should only be used with a seperate water pickup for the innercooler, elsewise the motor will not be getting enough water pressure, and will go into guardian mode.
I will post the spark arrestor pictures as soon as I get them.
Chris
Chris
#40
Chris
Stock, some of the water flow is diverted away from the heat exchanger, and thru the innercooler, reducing flow and psi thru the heat exchanger.
Chris
