If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: Boost
  1. #21
    VIP Member VIP Member Back4More's Avatar
    My Boats:
    353 Fastech
    Join Date
    Feb 2002
    Lake Michigan
    A very wise person once told me that Boost is your friend...
  2. #22
    Registered VIP Member
    My Boats:
    1998 Scarab
    Join Date
    Oct 2004
    Long Island, NY
    Quote Originally Posted by HTRDLNCN View Post
    Dont know if this helps but I will throw what little I know in here:
    Boost is the measurement of resistance to airflow not the actual amount of air being "pushed". The harder it is to push thru the resistance the higher the boost reading.
    Example: A blower that makes 10lbs of boost on a stock
    motor with stock components will make probably only about 5lbs of boost if you put big heads,cam,intake and exhaust on the same setup because you have lowered the resistance to air flowing thru the entire engine.
    another example: 5lbs of boost on a 502 big blocks requires almost twice as much air to be "pushed" than 5lbs of boost on a 350..
    Take a turbo rated at 20lbs of boost off a a small engine like a 4cyl Import sportcar and put it on a 600" V8 and it may not even make boost because the engine requires more air than the unit can push.
    CFM is a much better qualifier for a supercharger than boost.
    I didn't understand anything after " Don't know if this helps", but I am very convinced that you know your stuff
  3. #23
    My Boats:
    PQ 260/Laveycreft 29MCOB/ Now Boatless :-(
    Join Date
    Mar 2007
    Lake Dallas, TX
    engine uses certain amount of air per stroke.
    If you increase the heads ports/volume,bigger cam,intake/exhaust
    now the same size engine will use more air per stroke,
    if the the blower was making x amount of boost before upgrading the engine now it will make less boost after adding the better parts even though engine size stayed the same.. In extreme cases the blower will not be able to feed the engine any longer and little to no boost so you step up to a bigger one
    hp is made by air+fuel not engine size.
    Just so happens the bigger the engine the more air+fuel it can use naturally aspirated but once you add forced air induction engine size can become much less important.
    Formula style car race engines can make 1000+hp from tiny engines by running insane amounts of boost.
    This is not taking into account heat either.
    5lbs of nice cool room temp boost is not equal to 5lbs of boost of 200deg air which can happen when you overspin a blower with no intercooler.
    As you heat the air it expands which will read as higher boost but in reality it is just hot air.
    There is some good reading online if you search the phrase "Boost Vs Flow"
    So if remember correctly it's PV=nRT, Ideal Gas law, pressure*volume = #ofmoles*constant*temp. Change the temp it will change the pressure.
    Cool I have a pretty good understanding now, the bad news is now I want to go out and buy a blower.
  4. #24
    Registered VIP Member HotPursuit's Avatar
    My Boats:
    40 Skater
    Join Date
    May 2004
    "Simple terms"
    Boost is like sex the more you get the more you want!!
    The more you get the more it cost!!
    That said I have run supercharged power for 25+ yrs and have broken every part man can make but would never go without.
    Attached Images Attached Images
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
