volvo vs bravo
Old 02-18-2010, 05:39 AM
You can't go fast enough with the standard gear ratio's (1.5) @3,900 engine rpm's for there to be any noticable difference in speed or performance between the two drives.
HabanaJoe is offline
Old 02-18-2010, 06:09 AM
@SCOT BB;
MSA need service each 300 working hours (It mean oil change and nothing else), except bigg rubber pipe from transom seal kit which is from Mercruyser!
Two years ago I am have chance to test this drive:
Same boat typ with 2 steps, 4.200 pounds empty weight and with originall 496 HO engines.
- One boat with BravoX with 2 inch higher cavitation plate, bravo 1 prop.
- Second with MSA drive and maximus prop.
- Start by Bravo it was like each start. Bow up, brrrrr and slow acceleration
- with MSAit is like by dragster cars with out of any bow lift! It have speciall chanal for air which vented prop for better start.
- End speed with Bravo1X it was 69 mph.
- with MSA 79 mph until revolution blockade of engine. In my oppinion it is end speed of this combination round of 81-82 mph.!
Two days after test I am buy MSA drive and I do not care if it is first service 800 km from me. So what if have no troubles with it. It look bad yes, but who care, it is under water. And efficiency it is incredible better than by any Z drives.
MSA it is wonderfully drive if you need efficiency and it never blow out. This is surface drive with tunnel effect and you could use standard inox props like Bravo1 or Maximus.
Bigg diference in comparison with for example Arneson it is lot of trim effect and less chine walk of boat.
I do not know what meaning have this in USA, but it is reall quality maded Germany product.
When you install it, you do not need to take care round of X dimension like by Z drives. You only mount it like it is writen in papers and rest make trim.
p.s.
Sorry for my bad english, but I hope that you understand what I am want to tell.
bye
Saso
sinus is offline
Old 02-18-2010, 10:57 AM
what cost would be involved in changing from 1.5 to 1.36
gerard is offline
Old 02-18-2010, 02:48 PM
Rik
arneson-industries.com
Offshoreonly Advertiser
Rik's Avatar
Just buy an Arneson Surface Drive.
Problem solved!
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 02-18-2010, 03:01 PM
Problem solved!
££££££££££££ asd8
gerard is offline
Old 02-18-2010, 04:02 PM
Neno the mind boggler
glassdave's Avatar
Originally Posted by gerard
££££££££££££ asd8
English translation
£ = $$ (at today's exchange rate)
but
Bravo ≠ Arneson asd8
in fact . . . . Bravo × Bravo × Bravo is still not = asd8 . . . (or Bravo^3<asd8) . . so the math kinda works in favor of the Arneson after the variables work themselves out. . . . . . You'll only buy one Arneson and they are well suited to this application.
08 OPA High Points Champion
glassdave is offline
Old 02-18-2010, 04:06 PM
fountain4play's Avatar
Problem solved!
LOL... Hey Rik,
I was wondering when you were going to pop in...
Jim
PS: Can't go wrong with Arneson's...
fountain4play is offline
Old 02-18-2010, 05:01 PM
i know what your sayin is right tho a asd 8 would be out of my budget right now
if i could only afford an asd 8 i would put it on my 440 yanmar diesel
maby rik will take installments and have his drive promoted in ireland
gerard is offline
Old 02-18-2010, 05:38 PM
Rik
Rik's Avatar
££££££££££££ asd8
What, a little over 10K £ and one hell of a lot of value there. that German thing is........
Rik is offline
Old 02-19-2010, 05:30 AM
Jassman's Avatar
Arnesons..who makes them..are they any good..are they almost as good as a bravo
Jassman is offline
