Which Boat Runs Better In Rougher Water..33 PP Or 33 AT >
Old 03-28-2010, 01:01 PM
Jassman's Avatar
Originally Posted by 302Sport
i have a 33PP and my best friend has a 33AT w/525s that i have about 100hours in so i have been in both for a lot of hours......what do you want to know??? the PP has a softer entry due to being a true v, the AT has a pad so its a little stiffer ride.....that being said, i think these boats are very close in the rough and it depends on the driver and set-up. i think my boat has an advantage over the 33 AT because i have #4's on boxes which puts my props over 4 feet off of the transom
Thanks for the info..good comparision. Thanks Jeff
Jassman is offline
Old 03-28-2010, 01:53 PM
A T is still in the biz.
powerplay not .
so if you need anything from the builder A T " pat " will be there .
"dan" from powerplay who know's where he's at
mike
mikebrls is offline
Old 03-28-2010, 04:35 PM
ed on the board here worked at PP and still has the contact info to get every part that PP used back in the day. Also Pat at performance marine can get you anything you need for your boat if you have a PP....
302Sport is offline
Old 03-28-2010, 05:17 PM
I have been in the 32AT and the 33 PP , That's why I own a 33PP. Softer ride in the rough talking about about real 3 to 4's. Therefor, I do not know the ride of a 33AT.
baja27 is offline
Old 03-28-2010, 05:18 PM
MidOcean's Avatar
Where do you plan on finding somebody that has riden in both besides me? And you know my opinion....
I've been in both.. Inboards. Liked both. Bought a Powerplay... with triple 2.5's though.
Attached Thumbnails Which Boat Runs Better In Rougher Water..33 PP Or 33 AT-dscn0707.jpg
MidOcean is offline
Old 03-28-2010, 07:04 PM
ActiveThunder's Avatar
33 AT? Different model than 32. 32 AT and 33 PP are basically same boat. Just different splashes of the same ol' stuff. Best offshore at the time!
ActiveThunder is offline
Old 03-28-2010, 07:26 PM
Jassman's Avatar
What is the diff. between the 32 and 33 AT so I can better explain it to him. Is the 32 the same size as the 33 PP..Thanks
Jassman is offline
Old 03-28-2010, 07:32 PM
within inches. Bottom technology is the same. Sent an e-mail...
Old 03-29-2010, 03:35 PM
dkwestern's Avatar
Any other pics? Which boat is it?
dkwestern is offline
Old 03-29-2010, 08:37 PM
Side by side the PP is larger. The AT has a notched transom also?
POWERPLAY J is offline
