New Engine Dyno Results - Constructive Thoughts >
Old 03-27-2010, 08:02 AM
Question New Engine Dyno Results - Constructive Thoughts
Thanks for the input!
DucBoy is offline
Old 03-27-2010, 08:52 AM
mikes280's Avatar
why just a 850 seems small to me i run 1050's on a lot smaller motors and when going from a 850 on a 540 to a 1050 i made 30 more hp
mikes280 is offline
Old 03-27-2010, 08:59 AM
mikes280's Avatar
TQ curve is nice and flat hp # look pretty good for that cam and carb
mikes280 is offline
Old 03-27-2010, 10:19 AM
The way I read it he is running 2 850's.....
bobsbillets is offline
Old 03-27-2010, 10:33 AM
mikes280's Avatar
could be, i thought he was talking about 2 motors
mikes280 is offline
Old 03-27-2010, 10:43 AM
Chris
CB-BLR's Avatar
Torque seems low to me also.
My N/A 540 made 685hp/682tq with AFR 305 cnc's, a 1050 dominator carb, a victor intake, a 1" supersucker carb spacer, 9.4 lbs of compression, and a RMBuilder cam. This was with all accessories running, and through wet exhaust on 92 octane fuel. Bob told me I could have picked up another 20-25 hp with a set of AFR 315's, but I didnt have the coin at the time.
I would contact Bob Maderia aka RMBuilder for setting up that motor combination. I am willing to bet your cam is not ideal for your motor among other things.
His number is: 585-654-8583
Chris
CB-BLR is offline
Old 03-27-2010, 10:52 AM
Be Happy the drives will not hold what you have now..
just my 02ct.
customryder is offline
Thanks for the responses. Single 850 (two motors, one carb each). Used the 850s because I had them on the shelf - I think moving up to 1050s would make sense.
I should elaborate that my goal was usable power over the full range (including idle - it's a ways from the dock to the open water) with long-term engine reliability. I'm more of a fast cruise than an all-out race kind of boater.
DucBoy is offline
Old 03-27-2010, 10:54 AM
just my 02ct.
Yes, that is my next chore - learning how to rebuild drives...
DucBoy is offline
Old 03-27-2010, 11:12 AM
mikes280's Avatar
they also make a 1000cfm carb on a 4150 base , you could try without having to change the intake. But on the 540 that i got 30 hp out of with the 1050 we used a adapter for a 4500 to a 4150 intake i am sure a large intake would have made more.i am doing a 496 now and we plain to use a 1050 i did 2 of these 3 years ago and made 640 apiece so we are doing one more killer is the 496 made more power with the 1050 also.
mikes280 is offline
