testing new 5 blades
I just picked up a pair of the new hydromotive 5 blades for testing. They sure are pretty. Has any one else tested them out yet?
I'll post the results tomorrow. |
Maximus,
Jay Pilini at Spectre has done some testing with them with great results:cool: |
big #'s
Yeah, I heard Zipp got 113-114 with 500's I'll keep my fingers crossed I'm at 110-111 right now (running light) 106-108 (loaded).
would like to try 32 5 blades. Have 1high ass x. will pay to borrow and can be trusted with your hardware. I have bought and sold here, can give references
Maximus,
We've been running them on the F-275 FOUNTAIN GMC since mid season 2001. Have run from 29 pitch to 32, various leading edge changes. Tremendous stability and a very low slip factor. Also ran Herring 5 blades, both were quite similar in speed, handling etc. Price difference favored the Q-5s. Ours are NOT labbed. If you're in Fort Myers for the races stop by, we've got several sets in various stages of testing, eg: leading edge, different cup, etc. I tested them on my pleasure boat and had good results. Subsequently bought a couple of sets thru Ben Robertson. Now using their 31" Q-5 with 1.35 ratios. The F-2 boat is a 35 canopied Fountain. The pleasure boat is 43 feet, app. 13,500 pounds. Slip factor is less than 6% on the F-2 boat and somewhere near 9% on the pleasure boat. Take care, good luck. Steve |
Jeff,
Give Ben Robertson a call at the Fountain factory, or stop by in Fort Myers at the races with your boat and you can try a couple of different sets. No charge. Steve |
Thanks Steve, Ben and I know each other, I will. Sorry I missed your presentation in Sarasota. Dennis Philon (broker) asked me if I knew you. I Look forward to it in Ft. Myers in F-2. Mr. Technology F-2, Jeff Dean- Realtor
results!!
Here they are.
Baseline: 36 Spectre Poker Run (7200lbs dry)/ 500efi's /XR 1.35)/Merc lowers/hydro nosecones Bravo one 15 1/4 x 34 -4 blade Fuel: 50 gal Salt water / med humidity/ 72 deg Top speed -111 @ 5000 rpm (trimmed out- on the edge) cruise -91.5 @ 4100rpm feels good Acceleration- good bow lift - high Slow to plane True running- 1-2.5 ft- boat is a little "flighty" but fast finish- avg Hydromotive 15 1/4 x 31 - 5 blade Fuel 90 gal Salt water/high humidity/ 85 deg Top speed 108 @ 5250 ( liked med trim best) cruise - 89 @ 4100 ( very stable) Acceleration- good bow lift - low Plane- faster than B1's True running- 1-3's- very stable (felt 15 feet wide), boat accelerated very well in chop. Should be a great all around race prop. Point and shoot! finish- polished Notes- man these props look cool on the boat! Testing 5 blade Herring's tomorrow. MAXIMUS PS. Thanks for the offer and info STEVEDAVID I might take you up on that. I also found them to be very stable. lets see how the herrings do, then I try labe finished Brave ones. |
ANYBODY OUT THERE TRY THESE NEW 5 BLADE DEALS ON A SINGLE ENGINE CAT...WOULD LIKE TO KNOW THE RESULTS
Who do you know in order to get a set of Herring's to test......:rolleyes:
I talked to him at the Miami Boat Show and every other word had $dollar$ signs with them The Hydro's didn't do what you thought they would ..... did they? |
