best prop for pantera 28 at cruise >
Old 06-01-2010, 05:24 PM
Default best prop for pantera 28 at cruise
hi all
im running a stock 30 bravo on a merc diesel @3800 rpm getting 52 mph
the boat is 4900lbs
so what i was thinking my max rpm would be the same as your cruise rpm
what prop would you use for max speed at cruise 3800
cheers gerard
gerard is offline
Old 06-01-2010, 06:27 PM
have you tried a bigger prop let say a 32 pitch 4 blade and if you did what was the top rpm with that prop ?
if you were 200 or 300 rpm lower then your 3800rpm max you can lab a 32 and pick up the difrence in rpm and have a faster cruise speed
mike
mikebrls is offline
Old 06-01-2010, 07:24 PM
JC Performance Engines
Stormrider's Avatar
gerard, we need to know what rpm max torque is at, and what is max rpm for the engine?
Stormrider is offline
Old 06-01-2010, 11:58 PM
Received 1,821 Likes on 907 Posts
Your propslip is about 26% which is way too high. You should be able to get it down to around 16%. I ran about 52mph at 4000rpms with a 26 Bravo prop. Your boat is also about 400# lighter than mine was.
Where is the X dim or propshaft height set at?????
You may want to consider a 5 Blade Maximus or P5X prop.
Griff is offline
Old 06-02-2010, 05:41 AM
hi again thankyou all for your replys
the max torque is 526ft lbs @2400
and the max rpm is 4000
the x was 17.5 and i added a 1" spacer and it made no difference
with the drive tucked under the boat im getting 3600rpm 49mph
and when i trim it out i only gain 3mph
the cabin is gutted so there is little weight up front
i had a 28 b1 before the 30 and it was 50 mph @ 4000
gerard is offline
