Need 40 psi pressure relief valve....
for the raw water system on my HP 525EFI. I can only find valves that adjust up to 25 psi. I want to run closer to 40 since that is what these engines like. Does anyone know where I can get one?
25 is way more than you need your fine at 25 on a closed system theres no problem with hot spots cause you have water always in the block thats the only reason to run higher pressure is on a open system
