Gas mixed with Race Fuel ?
Charter Member # 545
Seriously, higher octane than you need just ends up as carbon on your transom. Wont hurt anything, just doesnt burn completely. Hot air temp's and high humidity will make your motor lay down more than higher than needed octane. I have heard some folks say because of the incomplete combustion of the higher than needed octane you are not getting as much horsepower as you would with lower octane fuel burning more completely. Never noticed it in our 700's though.
It would idle really good, but under load or higher rpm performance would suffer. Higher the octane number, harder to burn. The opposite of detonation. Low octane fuels explode before piston is in optimum position of stroke. Higher octane -harder to explode. Hope that helps maybe not the best description but that how it works................................Rjr.......... ...............................
Octane less than needed by the motor and well...big check writing time may rear its ugly head! The higher the octane, the safer the motor. Octane greater than needed for the motor, the lower the power...but I doubt I could actually feel the difference in the boat's performance. In reality, buying too much octane is money that needs not to be spent...but it isn't "bad" in the sense of damaging a motor. On the flip side, if some claims higher octane than needed will increase performance...well, get a second opinion!
That said, the ratings on fuel pumps is not absolutely nescessarily an iron clad guarantee. So, I gladly err a bit and buy slightly higher octane than the motor needs. Especially if the motor is going to see tough duty. For example, when I fuel my tow vehicle that "needs" 89 octane, I will put in higher octane fuel if I know I'm going to tow a large/heavy trailer with that fuel.
On ocassion, I have been forced to buy 89 octane for my boat motors that "need" 92 octane. On those occassions, I avoid letting the blowers develop much boost for any length of time. Ditto for burning off a tank full of stablized fuel that has been in the boat during winter storage.
Dont worry Mark......you still have them covered this weekend at JOTJ's. The V's anyway.
The piece of mind is worth much more the miniscule loss of power, especially if your running hard
thanks Randy and Robert Jr......I am little suspect that the "mishap" that I experienced on the Jammin run last year may have been the result of less than rated octane fuel....I was considering adding some 102 aviation fuel to insure against this happening again.....sounds like if the mixture was a little high on the octane side it may hamper performance slightly but at the same time provide a little insurance....am I reading this right?
AV fuel will be fine as long as its mixed with some gasoline.
True "aviation Fuel" is formulated to burn at altitude not sea level. Check With AED Performance on J.D. Pike at willis rd.Richmond,Va They sell 102 and 106 octane race gas by the barrel. Blend it 3:1 3 parts pump gas to 1 part race gas will keep you safe. In other words don't buy it at the airfield!........................................R jr...................................
blending, you can go here.
www.bazellracefuels.com/Calcs/OC1.htm
I also run it in my lawnmower, Gator, My wife's Honda Ruckus, my old Corvette and everything else that can get messed up from the ethanol getting old.
I also treat every ounce of 93 octane fuel that goes into all of the above with the valvetect additive....the price of it seems small when chit isn't blowing up!!!
