How to center a steering wheel >
Old 02-05-2007, 10:35 AM
Registered User
Default How to center a steering wheel
I just replaced my steering slave cylinder, & noticed that my wheel is now off about 1/4 of a turn. Center is now at 3 o-clock vice 12. Is there an adjustment to the cable I'm missing, or can I simply remove the wheel & index it back to 12?
rangerrick63 is offline
Old 02-06-2007, 08:56 AM
Default Re: How to center a steering wheel
hyd steering has no center.. if thats what you have
customryder is offline
Old 02-06-2007, 09:08 AM
Charter Member #232
Audiofn's Avatar
If you have cable steering ya you can just re clock it.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-06-2007, 10:26 AM
Rough Seas Lie Ahead
Reckless32's Avatar
If it's hydraulic, what kind?
Reckless32 is offline
Old 02-06-2007, 11:14 AM
Registered User
Sorry, it's cable....
Not sure how to "reclock" one...
Old 07-31-2010, 06:31 PM
gripit's Avatar
ttt
Anybody know how to center a cable steering wheel?
gripit is offline
Old 07-31-2010, 08:05 PM
Neno the mind boggler
glassdave's Avatar
get a three spoke symetric wheel.
08 OPA High Points Champion
glassdave is offline
Old 08-01-2010, 08:58 AM
gripit's Avatar
LOL
gripit is offline
Old 08-01-2010, 11:43 AM
Forum Regulator
Sydwayz's Avatar
Received 1,195 Likes on 519 Posts
On almost all hydraulic steering systems, it can't be done.
Get a symmetrical wheel.
Sydwayz is offline
Old 08-01-2010, 01:11 PM
Too Stroked's Avatar
Originally Posted by gripit
ttt
There are actually several ways. First, most steering wheels have three positions that they can be locked down with using the center nut. This of course assumes that one of those positions works for you. First, straighten the drive. Next, loosen - but do not remove the center nut. Then, using a rubber mallert - tap the steering wheel from the back side to loosen it. When it's loose, remove the nut, the wheel, then clock it before tightening it back down. (You leave the nut on loose to avoid stopping the steering wheel with your face.)
A better option - assuming you have a steering rack that drives the cable - involves straightening the drive first again. Next, loosen or remove the four 7/16" nuts that hold the rack up against the cable. Carefully turn the wheel to the straight position, then bolt the rack back up. It takes about 5 minutes if you have decent access to the rack.
Too Stroked is offline
Quick Reply: How to center a steering wheel
