Found metal 1 of my engines. Need help with id. >
Old 08-04-2010, 09:51 PM
tomtbone1993's Avatar
Originally Posted by whoya
Im saying lifter to.
after reviewing the pics again I would have to agree
tomtbone1993 is offline
Old 08-04-2010, 09:54 PM
SORE MEMBER
Wobble's Avatar
Originally Posted by BY U BOY
nope those are the retro lifters when I went over to a roller cam..Shavings of 2 of my pistons when the crank broke and took out the rods, pistons and all.
holy chit, broken crank is somewhat unusual.
Wobble is offline
Old 08-04-2010, 10:31 PM
not with our group of friends....we manage to find a new way to break things...
Old 08-04-2010, 10:39 PM
BY U BOY's Avatar
If you want to break it let us use it
we are professional boat breakers
BY U BOY is offline
Old 08-04-2010, 10:48 PM
Expensive Date's Avatar
Cam Bearing? The little circles almost look like the spacers behind the spring in the oil pump.But its been a long time since I had a BB pump apart.
None of which explains the water in the oil.Most likely this damage was caused by the water in the oil.Sorry but I think you need a complete tear down.
Expensive Date is offline
Old 08-05-2010, 04:15 PM
Fountain38SC's Avatar
Unfortunately I think we have a winner. The upper end appears intact, compression is good so the news is bad. If I get time this weekend, I'll dig further into it & let you know what I find.
Thanks again for the responses.
Fountain38SC is offline
Old 08-05-2010, 05:27 PM
The small round pieces appear to be oil metering discs from a hydraulic lifter/lifters. The other stuff looks like bearing material.
cubicinches is offline
Old 08-06-2010, 08:54 AM
PatriYacht's Avatar
Wonder what's lurking in the oil pan?
PatriYacht is offline
Old 08-06-2010, 09:04 AM
I would tend to agree on the metering discs, however he didn't mention anything about lifter failure.
Rattlesnake Jake is offline
Old 08-06-2010, 09:10 AM
im not one to speculate,but my guess is a broken lifter,it does not look like main or rod bearing to me.the round parts look like parts from a hydraulic lifter.what tupe of liftre does the engine use,hyd or hyd roller?
mike tkach is offline
