Engine Install
Old 08-05-2010, 04:10 PM
Default Engine Install
Does anyone have a diagram of how the engine bolts into the transom?
I just bought all of the proper hardware but have never done it before so I am trying to figure out the order. Probably should have paid closer attention when I pulled the motor but it has been nearly 6mnths.
It is an IMCO SC drive.
Any help is appreciated.
ar15meister is offline
Old 08-05-2010, 04:13 PM
Standard bravo application using the two vertical bolts?
From bottom up - nut, transom mount flange, spring w/fiber washer, bellhousing flange, spacer, washer, bolt.
fantastixvoyage is offline
Old 08-05-2010, 04:15 PM
it is 2 bolts and I believe yes a standard bravo style.
Old 08-06-2010, 07:12 AM
Dave M's Avatar
Here's a diagram that might help
http://www.mercruiserparts.com/Show_...ND+SHIFT+CABLE
Dave M is offline
Old 08-06-2010, 08:27 AM
Tape up the washers so they don't fall off when your setting the engine on the transom assembly.
TexomaPowerboater is offline
Old 08-06-2010, 09:18 AM
Geronimo36
Panther's Avatar
That or some 3M weatherstrip adhesive on the fiber washers helps.
However, I usually lower the engine into place and slide the spring washer and fiber washer under the bell housing.
Panther is offline
