Running big water in a smaller boat, any tips
Enjoy the show
This video shows 3 to 4's with an occasional 5'
http://vimeo.com/13814205
Keep it level. Weight in the bow 1st, trim drives in 2nd. If it's still lifting the nose, drop the tabs a bit.
Wear a lifejacket and kill switch.
Have fun!
Have fun!
That would be 3's.. 3 foot wave+3foot trough=6footers. You are in 3's commen mistake.I here people all the time talk about being in 5,6,7,10,s around Cape Cod. I does happen,but your not going out in it.
In smaller stuff it's like with a hooker (I imagine)... Just plow through it all and don't care about much....
When it gets bigger then it's like with your future wife.... Take it easy, choose the right path be really careful or it can get VERY expensive, VERY dangerous and dare I venture BORDERLINE deadly....
Have fun now!!!!
Have fun now!!!!
------haha!!! i believe this is very appropriate for my first post! being engaged, this comment is so true.....
I enjoy 3-4's in my 28 as well. Completely different boating experience. I usually run hard staying on top until it gets too nasty (tabs up, trimed out). Then when the wife starts hollaring I just tuck the drives in, drop the tabs, and cruise around at 30mph. Its like a rollercoaster.....tons of fun. Even my passengers have a blast pounding through that suff.
My advice would be zero or a bit of negative trim and tabs as needed to keep the boat flying level. Too much negative trim, bow weight or tabs can lead to a stuff. Trust me, they hurt. So, you need to start out with drives tucked in, then know how much tab to start with, and add or subtract accordingly. As I already said, not enough tab can be almost as dangerous as too much. Finally, never go charging right out. It takes a bit to feel out the conditions and adjust accordingly.
Lots of folks think fling a boat looks sexy – and it does. The problem is that the landings each do a little bit of damage to something. That damage is cumulative – and sometimes doesn’t become apparent until the last straw breaks. Then it’s too late and generally very expensive. Why do you think they sell most race boats after one year?
Something nobody seems to have mentioned is proper use of the throttles. You’d better get used to backing out before you leave a wave and smoothly getting back in as your drives enter the next one. The only way to learn this one is practice though. You can’t read a book and go out and do it right. I’ve gone to a foot throttle and foot trim and would never go back in a sit down boat because it allows me to have two hands on the wheel. In stand up bolsters, positioning of your body is everything.
Finally, safety, safety, safety. Never go crushing waves without a PFD and your kill switch on. A helmet isn’t a bad idea either. My personal opinion is that I don’t like putting others at risk when I’m running hard, so I run alone in the boat. Your call here. Lots of innocent passengers have been hurt or killed because they weren’t paying attention.
