Thinking about buying a go pro camera.
#31
Here's a couple of vids on my ski using various mounts including the suction cup. Even though it's on a safety line, it has yet to come off, even as hard as I run it. Also, when you shoot at 720p wide angle, it shoots at 60 frames per second. That means you can slow it down to 30 frames (normal speed) and get some smooth slow motion shots. The only downside is their sound and how any shaking can get amplified. I am an audio engineer for a living, so I am able to squeeze out my engine noise and enhance things in general. GoPro offers a bunch of options to their mounts and I hope to calm down the rattling through that.
http://www.youtube.com/watch?v=twUdIQMGzUs
Also, get the anti-fog strips! That's what's up with the first clip.
Slomotion
http://www.youtube.com/watch?v=LCsfguQHkxs
Slomotion
#32
a good friend of mine got a new gopro and this is what we got the first time out. http://www.youtube.com/watch?v=_csmVp3QhKU
#33
The HD model is pretty new, although the one a friend of mine just got is different from the one I bought in May. If you're going to watch the videos on and older TV, a laptop or your phone, the HD is probably not needed. If you're watching on a mid-size or larger HD TV, go for it.
#34
Diamond Member #001
I should be clear that the only difference that I could determine between NASCAT's GoPro and mine was the markings. His came with updated firmware, but I was able to download the new version as well as an updated owners manual for free. The suction cup mount was part of the "Motorsports" kit that I bought. (It was good enough for a 127 mph run...)
#36
Another mount I found to be really helpful is the roll bar mount. It's very secure and camps on to any round-ish bar less than 2" in or so in dia. I got the ebay seller to throw that in when I ordered mine.
I had the fogging issue too. What I now do when possible is to leave the camera and case (open) in the sun a little while to drive off as much moisture before use as possible before I seal it. Drastically helps...
#37
Verdict is in go with the GoProHD much better optics...
Now I need another cam cause I lost the one on the snout in the lake yesterday!!!
In cockpit from yesterday.
Press "YouTube" icon bottom right of picture then in the new window press 720HD bottom right of picture where it says "360" and then "expand" right beside it.
[YOUTUBE]http://www.youtube.com/watch?v=X4HCfe-Xjc0[/YOUTUBE]
#40
The microphone is the weak point. Even though it fits snug in its casing, any part of the mount systems that rattles will translate to the mic. (Sound travels much better through solids) That's my only gripe and I am trying to mellow down the shaking to minimize that.
