If you can't find it....Make it. DIY fuel injection >
Old 11-09-2010, 09:21 AM
Default If you can't find it....Make it. DIY fuel injection
Here are some pics of a fuel injection setup I'm building. No one makes an injector plate and rail to go on top of either a roots blower or PSI that holds either 10 or 12 injectors. There are only 8 or 16 injectors, and the 16 setup won't work for me. So, I make my own. I've several of these in the past, so I thought I would put some pics up. Maybe someone will make their own, or I would be glad to make one for them.
This is going on top of a PSI, but it will work on a roots, B&M, top entry Whipple, etc. On top of the injector plate will be (2) 2000 cfm throttle bodies. The fuel rail has a 5/8" id, so it will really flow some fuel.
I put up a few more pics as I finish it up. Thanks for looking. Enjoy.
Eddie
Attached Thumbnails If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-3-large-.jpg   If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-5-large-.jpg   If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-6-large-.jpg
If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-7-large-.jpg   If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-8-large-.jpg
Young Performance is offline
Old 11-09-2010, 09:23 AM
Here are a few more with it all welded up. It's still not finished, so I will post more pics as it progresses.
Eddie
Attached Thumbnails If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-9-large-.jpg   If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-10-large-.jpg   If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-11-large-.jpg
If you can't find it....Make it. DIY fuel injection-psi-fuel-injection-large-.jpg
Old 11-09-2010, 09:33 AM
awesome work!
frickstyle is offline
Old 11-09-2010, 09:53 AM
That is way cool. I had been working on a similar project about a year ago. We were working on replicating some old school slide valves for a Porsche project, but instead of old mechanical injection, we were going to go EFI. Something like this, with all modern guts...
RT930turbo is offline
Old 11-09-2010, 01:59 PM
PF Marine
Coolerman's Avatar
very cool eddie, keep us updated
Coolerman is offline
Old 11-09-2010, 04:04 PM
That's the good stuff!
AO31 is offline
Old 11-09-2010, 04:12 PM
Expensive Date's Avatar
I guess Eddie got an A in metal shop.
Expensive Date is offline
Old 11-09-2010, 04:52 PM
It appears that way.
I can make it about as far as cutting a bolt or bending a bracket.
jeff1000man is offline
Old 11-09-2010, 05:12 PM
outriggers's Avatar
Dual ignition?, Theres an awful lot of wires coming out of that cap. Doug
outriggers is offline
Old 11-09-2010, 05:16 PM
Wink Innovation is the life blood of performance!
Good Job Eddie:
We made some pretty cool electronic injection for our 8.1L 496 thru 600 cubic inch engines.
Its a lot of designing, prototyping, engineering, tooling, etc,etc,etc. But if it were easy, anybody could do it!
Best Regards,
Ray @ Raylar
Attached Thumbnails If you can't find it....Make it. DIY fuel injection-raylar-ho750.jpg
Raylar is offline
