If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 3 of 3
  1. #1
    Join Date
    Nov 2010
    502 Carb Gen 6 Help.....
    Hi everyone,
    I need some help information, I bought a new crate 502 Gen VI from (Great Service) I blow 4 engines in the past 2 years with less than 4 hours on the water each. I swap mechanics as well and that didn't fix the problem ether, so I decide no more rebuild or use fly by night mechanics so I purchase a crate long block engine. Here are the specs of the engine: 435 HP, roller cam, single plane air gap merlin intake, stainless marine 4" thu transon, electronic marine ignition.
    What will be the best performance specs like timing (base & advance), spark gap, carburetor CFM.
    1995 Formula 25 Boating on this same boat since 2001 so I the driver I’m not part of the blowing engines issue.
    Your input will be very much appreciated.
    Thank you
  2. #2
    Charter Member # 55 Charter Member Griff's Avatar
    My Boats:
    ..........32........... Active Thunder
    Join Date
    Oct 2000
    Timing at 34* full advance at 3000rpms, shoot for around 14* base timing, but let it fall where it may.
    What ignition do you have????
    Spark plugs, AC MR43T or NGK BR6FS gapped at .035-.040
    800cfm Holley carb
    What failures did you have in the other engines??????? 4 blown engines with less than 4 hrs each sounds like a set up problem. Plenty of people have run 1800runsnew engines with good results.
  3. #3
    VIP Member VIP Member akaboatman's Avatar
    Join Date
    Aug 2004
    Baton Rouge La.
    I  Voted
    Ck your exhaust
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
