Will a 96  Fountian 29 ft Fever w/Twin 502 MPI run 85MPH >
Old 11-27-2010, 12:56 PM
Ok, this is not to start a thing about, wether or not the Fountains are the correct length. As in a beak-and-swimplatform descussion. I like Fountains..
But if you are looking for a maximum of 30', have you looked at a 32 fever? I haven't measured any and not been around alot of them, but just a thought.
A.O. Razor is offline
Old 11-27-2010, 03:21 PM
Kind of doubt it, my boat with 502's and 25p props runs 76 at 5200rpm around 7% slip
hotjava66 is offline
Old 11-27-2010, 04:02 PM
Originally Posted by SVL-WARLOCK
the single 575 runs around 84 on gps. the twin 377 boat does 85 give or take.
If you Don't mine saying what hp are you putting out. Do you think the hull with the single would run 100+ with 1000+ hp and handle
goebel1 is offline
Old 11-27-2010, 07:08 PM
Wink
My Opinion, no on both counts! Go find a later model with steps like the others recommended if you need 85+ mph in a real 29-35 foot hull with twin big blocks of necessary horsepower.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 11-27-2010, 09:09 PM
If it helps I run 69 fresh, 71 salt gps in an 1988 27/29 Fever with 1.5 bravos and stock 454/330's whether I run 25 mirage or 27 mirage plus is only about 300 rpm diff but same top speed. 27s run about 42-4300 rpm
Don't mid 90's fountains run a 1.32 ratio? Could that explain the 25p at 85mph?
prostock85 is offline
Old 11-28-2010, 05:01 AM
dykstra's Avatar
Originally Posted by goebel1
Will a 96 Fountian 29' Fever w/Twin 502 MPI run 85MPH?
No
dykstra is offline
Old 11-28-2010, 08:50 AM
If you want, come on up some weekend and you can run either one. You can see the difference.
SVL-WARLOCK is offline
Old 11-28-2010, 09:06 AM
My 97 454 mag twin 26 hydro 1.50 bravo 2 people low fuel runs 78.4 gps .
sirfartsalot is offline
Old 11-28-2010, 12:29 PM
I had a 97 with 454's and ran 78 as well. I really enjoyed that boat but it was a hand full.
twin screws is offline
Old 11-29-2010, 06:23 PM
LapseofReason's Avatar
This just poped up today should do 80.
http://washingtondc.craigslist.org/m...084954434.html
LapseofReason is offline
