PROS & CONS - Fountain 38 Lightning Twin Step Stagger 525 >
Old 01-07-2011, 10:51 PM
Default PROS & CONS - Fountain 35 Lightning Twin Step Stagger 525
Just curious about what the board thinks about the newer 525 full stagger 35s and how they compare to similar models from competitors. Questions.......
Good bang for the buck?
Stable at high speeds?
Decent in the rough?
Slow to plane?
Overall thoughts?
Top speeds seen with which props?
Any complaints about the 525s?
Current owners and haters alike, please give your opinions.
Thanks.
And yes it's closer to a 32 b/c of the beak.
salesdeity is offline
Old 01-08-2011, 05:55 AM
Charter Member # 545
Beak Boater's Avatar
Which boat are you interested in? Your thread title says 38 and your post asks about the 35.
Beak Boater is offline
Old 01-08-2011, 07:44 AM
Must be talking about the 35 because he says
"And yes it's closer to a 32 b/c of the beak."
NKissau is offline
Old 01-08-2011, 07:48 AM
sorry meant 35 originally. edit done.
Old 01-08-2011, 08:48 AM
great boat, but if you are going from a non stagger to a stagger you have no, or should say less cockpit room between front and rear bench,hard to go backwards, for me anyways. The 38 had same cockpit. I finaly sat in one in Nov., was ready to pull trigger on 38 but backed of.If your okay with cockpit great boat, slidding door for cockpit and if new enough great new cabin and does 100 with stock power.
JMPH is offline
Old 01-08-2011, 03:52 PM
Location: Ft. Lauderdale Florida & Tarpon Springs Florida
PRO .. 525's are a great engine
CON ... its in a Fountain
tanner is offline
Old 01-08-2011, 04:41 PM
a guy in our boat club bought a 38 instead of a 35 because the 35 was so unstable and loose on top end
Boomer35 is offline
Old 01-08-2011, 05:03 PM
Back4More's Avatar
http://www.youtube.com/watch?v=1QFHKKvAJGo
Back4More is offline
Old 01-09-2011, 08:49 AM
Received 1,329 Likes on 742 Posts
Wow only 8 responses, should have put MiniHawk in the title!
Wildman_grafix is offline
Old 01-09-2011, 09:18 AM
I would politely take issue with this.
Having three seasons in mine, I have never seen this hull get unruly on the high end. Even when catching the rogue wave and flying the thing it remains in control. Mine is the side by side configuration, the staggered boat is even better from my experience in one. A 35' hull at 90 to 100+ MPH does require ones attention, this hull will out run anything in it's class, and in a very safe and stable manner.
Would a 38 be better? Yes, but then a 42 would be better yet.
RaggedEdge is offline
