Catamaran's with/without Center-Pods..... >
Old 02-16-2011, 05:54 PM
Quinlan's Avatar
Conclusion:.....Buy a Skater
T2x[/QUOTE]
Thats all that needs to be said!
Quinlan is offline
Old 02-16-2011, 06:21 PM
Smile
Originally Posted by LESSONLEARNED
DCB with Pod...
Skater with no Pod...
Great,, Great pics LESSONLEARNED....
Perfect Example..... Both Amazing Boats.....
DCB / Skater
THANKU...!!!!!!!
PokerRun388 is offline
Old 02-16-2011, 06:23 PM
Smile
WOW,,, the DCB and Skater are alot different looking than I thought w/ that DCB center pod....
GREAT EXAMPLE N PICS... THANKU!
Old 02-16-2011, 08:02 PM
T2x
Or an American Offshore
Or a Doug Wright
Or a Jaguar
Or a Motion
Or an MTI
Or a Nor-Tech
Or an Ocean Express
Or an Outerlimits
Or a Platinum
Or a Spectre
Catmando is offline
Old 02-16-2011, 08:15 PM
GLH
GLH's Avatar
Originally Posted by Catmando
Conclusion:.....Buy
...something... anything... and... run it....
GLH is offline
Old 02-17-2011, 04:11 AM
[QUOTE=Quinlan;3328420]Conclusion:.....Buy a Skater
I take exception to that. Buy a center pod if you boat on lakes and rivers most of the time and want a cabin of any size. You can also go in some ocean swells and spend the night or get out of the rain and go down below with the lady of the boat.
ElimiNordic is offline
Old 02-17-2011, 05:36 AM
Centerpods are not simply a mistake by westcoast builders. They give better low speed manners to the boats. They plane at lower speeds, turn better at lower speeds, have less tendency for hop. They are certainly not an asset for offshore performance, but they were never designed to be that. They were designed to be more fun to operate in lakes and rivers. Take a ride in mine during a very rough poker run and you will get out with out bruised legs and shoulders. Quinlan, Cat, Tx2 come take a ride in my DCB.
SkiDoc is offline
Old 02-17-2011, 06:20 AM
hey C'mon Eric what about me ??? I owned an ELIMINATOR once
Attached Thumbnails Catamaran's with/without Center-Pods.....-downloan-pix-7-7-09-cd-018.jpg   Catamaran's with/without Center-Pods.....-downloan-pix-7-7-09-cd-020.jpg   Catamaran's with/without Center-Pods.....-downloan-pix-7-7-09-cd-021.jpg
Catamaran's with/without Center-Pods.....-downloan-pix-7-7-09-cd-015.jpg
Old 02-17-2011, 06:25 AM
SS930's Avatar
LMFAO, I just about pissed myself!
Originally Posted by T2x
Center pod cats were created after PowerCat Boats added a third "hull" to their line back in about 1960 to allow for a single engine in the center rather than duals. This has always been the reason why center pod cats exist....to allow for single engine propulsion. The pod will "protect" a center engine. The drawback is less airflow in the tunnel and therefore less lift which translates into lower speed at a specific wgt/hp. A center engine will also "trip" a cat when re-entering after being airborne at a high attack angle. The pod will also cause a bit of this alone, but without the severity. Since most West Coast cats are derivatives of each other, what you have is basic copying going on . So if one west coast cat has a pod...most of the rest do as well.
Bottom line, the pod cats have never been as competitive as non pod designs. This has often been disguised by putting huge HP in them to make up for the speed disadvantage and thereby proving the adage "if you put enough hp on a barge it will go fast".
One other thing is that the pod boats do not lope (porpoise) as much as the true cats because they do not have as much air beneath them to have a true transition from hydrodynamic lift to aerodynamic lift. They are more like a vee bottom with pontoons in that regard.
T2x
The man that would know summed it up well.
I would agree the pod boats do have a place on lakes and rivers, but this is OFFSHORE ONLY isn't it???
PeckerPuller, if you want to actually LEARN something rather than looking at pictures, playing with your toy boats, and coloring books, go read T2x's "Great Moments in Cat History" thread. You might actually learn a thing or two.
Or maybe not...
SS930 is offline
Old 02-17-2011, 06:52 AM
I guess it is Offshoreonly, but why do Skaters show up at Lake Cumberland? Bill you are welcome to take a ride or come and drive. Hopefully will take it to Kentucky Lake for the fun run. You've got to make the Lake Cumberland run this year.
SkiDoc is offline
