Best 12 volt air compressor >
Old 03-23-2011, 09:50 AM
Default Best 12 volt air compressor
I am considering purchasing one of those all in one battery boosters with air compressor. Anyone have any experience with these? I was considering the wogan. I would like to be able to fill up a small dingy in a reasonable amount of time. That is the Most important, but a battery boost just in case would be a nice to have.
Thanks for the feedback.
momolambovt is offline
Old 03-23-2011, 04:42 PM
Diamond Member #001
C_Spray's Avatar
The problem is that compressors are about pressure, not volume. I am not aware of any booster packs that include an inflator, which is what you need.
C_Spray is offline
Old 03-23-2011, 06:59 PM
+1. i got a compressor thinking I was smart, just to fill up rafts and stuff at the sand bar. It's easier and faster to just blow them up like we used to.
VetteLT193 is offline
Old 03-23-2011, 10:20 PM
Diamond Member #001
C_Spray's Avatar
i have the Airhead AHP-12hp pump, and recommend it. It's a bit noisy (screams), and you cannot use a cigarette lighter outlet (too much amperage), but it will inflate (and deflate!) way faster than anything else I've seen. I got mine at Cabela's, but I think Sears carries them as well. Roughly $55.
C_Spray is offline
Old 03-23-2011, 10:28 PM
Viaair is great stuff
http://www.viaircorp.com/
UD
Uncle Dave is offline
Old 03-24-2011, 02:08 PM
Don't get an all-in-one battery box/compressor. If you want to go that route get a separate pump and battery box. Both are handy to have if you have large inflatables, but they don't make a high quality combo device. IMO the only good battery boxes are the Solar brand packs found here:
http://www.tooltopia.com/solar-es250...googlebase_18u
They are the same battery box carried by towing companies, and there is a reason for it. The charge indicators on these boxes ACTUALLY WORK (rare for the cheaper brands), and they put out enough amperage to compensate for a battery that has a dead cell in it. The $40-60 dollar Sears/Home Depot battery packs, in my experience, are complete junk.
When I had inflatables on my boat I had a device that I got from West Marine called a "Turbo pump." It was in inflater and deflater, and it would blow up an entire "fun island" in about 20 minutes. If you think it is easier to blow up one of those things by hand (or mouth), go for it, and tell me how it worked out for you next week...
wjb21ndtown is offline
