If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Results 1 to 2 of 2
  1. #1
    My Boats:
    Sonic 31SS, 2001
    Join Date
    Apr 2011
    Goose Creek
    Sonic 31ss 2001 engine doesn't want to start, fuel pump issue?
    Needs some help, I have twin 454's and after running my boat for a short time, or a longtime and shutting boat off my left motor doesn't want to restart. I will attempt to start and it may take a few tries or 30 minutes and it will fire up. My rpm gauge for left motor differs over a1000rpms when I throttle up, but catches back up once I get on plane. I have cool fuel system just pulled it off and am going to replace fuel pump, is this the culprit? Also should I replace fuel regulator as well while I have it out? Any help or experience with this problem would help .
  2. #2
    Charter Member #1055/Moderator Charter Member GO4BROKE's Avatar
    My Boats:
    Sonic 386
    Join Date
    Feb 2001
    I  Voted
    Sounds like vapor lock. The tach reading off is probably the tach itself, especially if its a faria. Tap on it and see if it drops. Before you throw parts at it, check all the lines for looseness, a loose clamp can cause that problem. Have you tried feeding that engine from the other tank? Do some vapor lock searches in the tech forum, there have been a lot of threads on it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
