If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
  1. #11
    VIP Member VIP Member Marginmn's Avatar
    My Boats:
    38 Donzi ZRC, 29 Advantage XFlight
    Join Date
    Dec 2001
    Indianapolis, Lake Cumberland, Cape Coral, FL
    My 38 Fountain with full hydraulic doesn't do it at all, my friends 29 Advantage with full hydraulic doesnt do it either, my 29 Advantage (same hull) with cable over does do it.
    The Beak be gone
  2. #12
    CMC is offline
    Gold Member Gold Member
    Join Date
    Jun 2004
    New Jersey
    On single screw set ups, propeller torque causes it. It may seem like you want to adjust the wheel to compensate for it, but if you leave the wheel straight, the bow will usually partially come back > Of course all boats are slightly different.
  3. #13
    My Boats:
    03 PowerQuest Revenge
    Join Date
    Mar 2001
    Marblehead Ohio
    The trim tabs all the way down will eliminate almost all of the wandering...
  4. #14
    Platinum Member Platinum Member Dkahnjob's Avatar
    My Boats:
    Hallett 270T, & Barron Sprint flat bottom, Fountain 35 Lightning "sold"
    Join Date
    Oct 2006
    West Hills, CA & Lake Havasu
    Quote Originally Posted by 30ctsutphen View Post
    I am dying to hear the responces on this myself, I see this allot even on smaller single's and While I think sometimes its set up, like toe in or out on the tie bar or something I never have fully understood what the causes it for sure.
    Bad bushings on an older boat I would imagine can cause it as well, but I am no expert on this sort of thing at all.
    I hope someone has a definitive answer
    Does the boat do it all the time in every slow moving situation or only sometimes in some places?
    The boat only has 300 hours on it and everything is like new. I checked and there isn't any play anywhere. The steering is cable to the inside of transom and the hydraulic rams on the transom. Yes, it does it all the time, some times worse than other but un acceptable all of the time.
    I even tried idling on one engine to see if that helped, it did a bit, but still no joy.
    My last boat was a Fountain 35 lightning and it was not like this, maybe only a little, but not a problem. I should have kept it!
    Kahn Job
    Fountain 35 Lightning Classic
    West Hills, CA & Lake Havasu, AZ
  5. #15
    Beak botr VIP Member 88Fount33's Avatar
    My Boats:
    1988 Fountain 8.8
    Join Date
    Dec 2003
    Cape Coral
    Look for the drunk midget in the bilge!
    Yes, I said that!
    He only has enough strength to push the steering arms side to side when the boat idles! At speed, the noise makes him hide in his special place.
  6. #16
    Ginger or Mary Ann? Charter Member US1 Fountain's Avatar
    Join Date
    Oct 2000
    Lafayette, IN
    My 27 with a single did it, and it had hyd steering. I don't believe it is a type of steering issue, just a nature of the beast. Tabs and drives down helped, idleing just a tad faster does away with it. I found it best to not try to correct it by counter steering. Seems the lag time was always off. Just point in the direction and let'r go.
    My 32 (hyd steering) and 29 (non hyd) twins do not.
  7. #17
    Join Date
    Jul 2008
    Quote Originally Posted by Marginmn View Post
    My 28 is fully hydraulic stem to stern- wanders.
  8. #18
    Platinum Member Platinum Member Too Stroked's Avatar
    My Boats:
    Progression 22 w/ Diamond Marine Mercury 2.5 / 200
    Join Date
    Apr 2010
    Rochester, NY
    I think you’re going to find three common causes for this one. First is hardware related when steering components wear or wear out. Wear leads to play and play leads to wandering. But, as you said, your steering components seem to be in good shape.
    Next is hydrodynamics. Some hulls just wander more than others. This gets into a combination of drive height, hull length, deadrise, etc. The sad truth is that some hulls just wander more than others. I’ve seen some that are pretty darn scary, but as has already been mentioned, if you leave the boat to its own and don’t “over correct,” these boats will generally “wander in a straight line.”
    The third reason is wind and / or current. I remember bringing a customer’s 26’ Celebrity cruiser down a channel one day with a gusty 25 MPH cross wind. One minute I was going straight, the next minute I was headed straight for the pier. That was a real “Depends Undergarment Moment” – if you know what I mean.
    Where it gets really interesting is if you have more than one of the conditions I mentioned above. For instance, let’s say you have a hull that naturally wanders, with bad steering, on a windy day. That’s when you let the wife drive.
  9. #19
    My Boats:
    Open Slip - formerly Formula'd
    Join Date
    May 2007
    Akron, OH
    It's the nature of the beast - particularly for a single- screw boat...prop rotation will naturally want to turn the boat one direction--your correction starts a never-ending cycle at slow (idle)speeds. As mentioned above - putting the trim tabs down a little will even this out and make it a little more bearable.
  10. #20
    Registered bimini run's Avatar
    My Boats:
    1998 21' Baja Hammer
    Join Date
    Jan 2001
    Long Island, NY
    I've heard it referred to as bow steering and wandering. My boat has done it since brand new, a 21 ft. Baja Hammer. I think it's a combination of the hull, waves, and set-up, but deep Vs are prone to it. Some I guess more than others.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
