Boat wanders side to side at idle speeds, Why?
Many deep vees and many years and ......they all do this, some more than others.
Leave it alone and it will go where you pointed it, it is "hunting"
The biggest error made by most new race drivers, was over correcting. The boats are much better than most drivers, leave them alone and they will take care of you.
I have had a bunch of singles and every one did it except for my 06 28 Active Thunder but it had full to the helm Hyd steering and a ITS XR drive.
I have never seen a twin with atleast a tie bar do it.
Did you say you have external Hyd? If so that is very odd.
my 32 does it...hunting is what i was told, is it the nut behind the wheel??? I have not tried putting the tabs down.
Agreed. On a single the prop wants to claw the rear end out to the side at slow speed. A little more speed and the hull and the skeg and lower unit overtake the side torque. Take it out of gear at the same speed the boat wants to wander and it goes straight!
My Donzi did it Bad, I got tired of correcting it and found that if you don't touch the wheel it will correct it's self and wonder to the other side and correct it's self the other way ans so on. if there's alot of boat traffic you need to keep it in check but idleing by your self try to not touch the wheel and watch it do it's thing from side to side but still go where you pointed it to begin with..
Can You Hear Me Now??
Currents will also affect it but it comes from over compensating. It is very difficult to have the drives perfectly straight at that speed so any bit to left or right and it will take the boat a bit of distance but it will steer that way. Then the driver turns the wheel the other way thinking they are straightening it and they are over compensating the other way. I have had several v's and always have a long idle out so I am very familiar with it. Set the wheel straight and move the wheel half of what you think you need and over time it becomes second nature you won't even realize you are doing it. I'd it does it at speed then you have a steering issue.
Registered User
Yes, it does have a tie bar and hydraulic steering on the transom, but it is cable from the helm to the inside of the transom.
I measured the drive spacing and it appears that the drives are towed out about 3/8" Measuring the drive spacing on the front of the nose cones the front is about 3/8" farther apart than the back of the props. Are they supposed to be towed out or in????
-Dan
