My friend in Cape Coral FL put big power in a 34 SH.
It was a nightmare, pulled engines and sold boat. |
Yea whats up with the riser spacers? I know they need to go over the other engine but? Hey Payton, does yours have risers like this one?
1 Attachment(s)
Nope, I found a set of Merc/Gill manifolds and risers for a triple setup. Then sold the set I didn't need. Stock, mine had one of those extensions not 2.
Figured out why the high risers. To clear the injection on the 502's they went over the intakes. I am going carbed so I dont need the risers.
Headers or manifolds.
Payton, Hopefully I can pick your brain. I am almost ready to install a pair of procharged 468's in the new Super Hawaii and I am down to the exhaust. I know you changed your exhaust and I was looking to install headers. Is the port side (farthest back) exhaust a standard bravo setup? And I dont see a riser with your new setup, if I use a standard bravo header on the starboard side, wont the inside header terminate into the port engine. I have a concern with the rise of the starboard headers. I cant tell if your Gil setup on the starboard side in the pictures has a taller rise than the port side. Any help would be appreciated as always.
Yes the Gil riser on the forward engine is 6" taller than the rear. Then I have a factory tailpipe before the thru hull tips. The one on the outside, under the gunnel, I had to shorten about an inch for clearance. The one on the rear engine is standard Bravo riser.
3 Attachment(s)
First pic is when it was stock. Second pic is the Dry pipe that I cut to fit my tips.
Payton, thanks for the help again, I hope to have it in the water by Memorial Day.
Very cool! With all the rain we are getting I may not be ready by then. My new Air Dock came yesterday, so I am getting excited.
