lorviorsi gps batt change??? >
Old 04-21-2011, 03:38 PM
I'll be doing that. Thanks
dodgeman111 is offline
Old 04-21-2011, 04:23 PM
To all... and note to self... while trying to re-solder the tabs on the new battery for my GPS speedo, too much heat on battery causes battery to explode... FYI... just buy a new antenna... lol
teamsynergy is offline
Old 04-21-2011, 06:19 PM
Originally Posted by Dave M
Real easy, connect the blue wire from the gps harness to the signal wire on the speedo. Then go into the "Comm" menu on the gps and make sure NMEA output is selected.
Signal wire on my speedo was the orange. Unless you have an amp connector tool and a new connector and pins that fits the speedo it's easiest to cut the factory antenna harness and solder the orange wire to the NMEA output wire from your gps.
If you don't have a gps you can connect the antenna direct as I did.
THERUSH is offline
Old 04-22-2011, 07:11 AM
Dave M's Avatar
Yes, the wire on the speedo side is orange. My speedo came with an extra connector that just had the signal wire. So. I plugged it in to the speedo and spliced the blue from the GPS to the orange on the speedo.
Dave M is offline
Old 04-22-2011, 07:30 AM
GLH
GLH's Avatar
I got rid of my GPS speedo, I have speed on my GPS and the handheld attached to my dash...
GLH is offline
Old 04-22-2011, 07:53 AM
Registered User
Going to the battery store this weekend to try and get the battery replaced. Do you guy's really think they have to be recalibrated after? I don't buy it?
sunsation96 is offline
Old 04-22-2011, 08:05 AM
No,replace the battery and you will be good to go...
you can allways check it with a hand held one
boatnt is online now
Old 04-22-2011, 08:08 AM
Registered User
I was just headed to your side of town to ask you Thanks for the help I hope this works! Good idea I will also check it, just can't see why a battery change would affect the unit.
Old 05-03-2011, 06:43 PM
offthefront's Avatar
anyone got an old antenna I can beg,borrow or steal the small 3 pin connector off of? I need the connector and about 12" of pigtail .......m
Attached Thumbnails lorviorsi gps batt change???-p1000704.jpg   lorviorsi gps batt change???-p1000706.jpg
offthefront is offline
