If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    My Boats:
    Join Date
    Apr 2010
    Lake Travis
    Quote Originally Posted by wjb21ndtown View Post
    No, the 330s do not have forged lower components. They have cast pistons and the smaller rods. Some people have gotten 500hp out of them, but personally I think they're playing with fire. I would upgrade at least the pistons and rods before pushing it that far.
    This page says they have forged rods, just not pistons.
    Regardless, excessive cylinder pressure or RPM are what will kill it. I would think you should be able to get away with a fairly aggressive heads/cam/intake/carb combo that should make at least 500 hp and be good as long as you don't spin it too high.
  2. #12
    VIP Member VIP Member
    Join Date
    Oct 2006
    If you have a 365HP engine that is rebuildable, and you plan to supercharge it, contact rmbuilder (on this site) at Marine Kinetics. He is one of the best when it comes to cam setups. You need to know if the 365 heads are in good condition as well as the block and rotating assembly, one common problem with the old Mark IV heads was cracks around the valve guides.
    Another route to building 525SC engine ( about 500 prop shaft horse power) would be to re-cam the 365 with a crane (old number 132561 hydraulic non roller cam that came in the old 400, 405, 420, and 525SC Merc HP series engines.) you need the above cam, valve springs, crane gold roller rockers, gil manifolds, and a Weiland 177 blower and holley 800 DP. There are likely better cams available than the 132561, but this is the cam Merc used for the above engines.
    You could also contact Comp Cams and tell them what you are building and they likely can suggest a good cam for your build.
    As always, horse power just depends on how thick your wallet is.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
