Teague Custom Marine 1335/1365 Engines Earn CARB Certification >
Old 04-21-2011, 10:13 AM
What are the current regulations in Cali at the moment? Do new performance boat sales HAVE to include a CARB certified motor regardless the size? I was involved in this a few years back and at the time there were going to be exemptions for say engines over 500hp or so. Is that no longer the case?
fantastixvoyage is offline
Old 04-21-2011, 10:45 AM
Originally Posted by soggy bottom
It's nice that it is rated for 2500 hp, but it is still only a single speed trans, what is needed is a multiple speed unit, and until then all you are going have to chose from is proping to small and being able to get up on plane and then bouncing of the rev limiter, or proping it for top end and barely being able to get on plane with passangers and a decent amount of fuel, until one is avilable in masses those six figure powerplants will never see there true potential.
BigYellowCat has already done that. His two speeds are on the market now and are rated to handle his 2400hp rotary motors with 1900ftlbs torque.
Even the multispeed Weismann transmissions will handle the Teague motors.
Catmando is offline
Old 04-21-2011, 11:27 AM
Offshoreonly Advertiser
Mbam's Avatar
I was wondering what was going to happen to the independent builders, if you can understand it here is an interesting EPA doc
http://www.epa.gov/nonroad/marinesi-...8016-chp03.pdf
Tyson has done a great job on the 2 speed. As far as single speed transmissions go the VD looks good. We are adding them to our product line. I will have pricing and installation drawings soon. They are a bit longer than the 72 series currently in use, but it is the same unit for both driveline & plug in style which is nice! You either bolt a flange or an adapter plate on the back.
Mbam is offline
Old 04-21-2011, 12:43 PM
Thanks-! Great link.
What a nightmare. This means one thing for sure- prices are going up.
Interesting doc loaded with great info-
"Ilmor commented that they estimate that 80% of the High-Performance engines are produced by 5 or possibly 6 manufacturers. (Mercury, llmor, Teague, Sterling, Flagship, Chief). An additional 10-20 very small businesses, produce as little as 15-25 engines per year each."
If tohastu thinks they are going to be squeezed imagine the little guys.
UD
Uncle Dave is offline
Old 04-21-2011, 06:35 PM
Correspondent
Correspondent
Received 2,741 Likes on 1,230 Posts
I've had a couple of questions via email on how long those transmissions would last at their maximum rating of 2,500 foot-pounds of torque. I am going to try to find an answer.
However, my best guess is ... not very long, just as an engine capable of producing that level of torque likely can't produce it for very long before it fails. But if a product is rated to handle a certain max output, and your highest output is well below that max, the product should last.
In other words, I suspect the transmission in question is overbuilt—a good thing in this case—for its intended use.
Matt Trulio is offline
Old 04-21-2011, 07:34 PM
Comanche3Six's Avatar
Manufacturers specs.....
http://www.velvetdrive.com/Liberty72Brochure.pdf
Comanche3Six is offline
Old 04-21-2011, 08:49 PM
dkwestern's Avatar
Originally Posted by Comanche3Six
What are the graphs showing on the link. Delivers 1425hp at 5000 rpm. On what engine? Makes no sense to me. Is it assuming a constant 1500ft/lbs throughout the the entire rpm band? I'm confused????
dkwestern is offline
Old 04-21-2011, 08:57 PM
Mbam's Avatar
Yes, 1500 ft lbs constant. The horsepower depends on the RPM,
HP = 1500 x RPM / 5252
Mbam is offline
Old 04-23-2011, 06:09 PM
Whipple Charged's Avatar
Originally Posted by Uncle Dave
The testing is at a state level with the California air resources board - or C.A.R.B.
These guys are nasty strict- to the point that we cant even buy regular fuel cans anymore- they all need big brother caps et all.
Uncle Dave
We tested here at our facility. Marine is a little different than auto.
Whipple Charged is offline
Old 04-23-2011, 11:17 PM
Cool! Id bet you guy have word class facilities then.
How many specs does a carb engine have to meet?
UD
