Drive Stuck in Up Position
Xtreme Cooler Test Dumby
This may be a long shot but have you checked the Trim height adjustment switch on the side of the drive??? Maybe it came loose and won't allow the drive back down. I think it's held in posistion with two philips head screws.
Boating is fun, Isn't it ? For every problemless day, there is 15 problem days. Don't let anybody tell you different. It doesn't matter if you spend 50 grand or 500 grand, their is always a problem. If they made boats as reliable as cars, the boating industry would be screwed. They rely on boats being tempermental. Could you imagine that you would be happy if your car ran 100 hours and didn't need a complete re-build, like your boat engine(s). Crazy stuff. The technology is there. What about turbines ? They're supposed to be the most reliable things on the planet. Could you imagine if the " Apache" helicopters that all these turbine motors for boats supposedly came from performed in the choppers the same way they do in boats. Their would be an awful lot of fatalities. Turbines in planes are supposed to last " forever ". We all know that nothing lasts forever, but just imagine being in a plane and the captain talking to you on the intercom, and he says " we're running un-opposed on this flight, so we're going to slow it down so we don't break all of our equipment". My point is., a fast, high performance boat can be built to be reliable, someone just has to do it. It will piss off the other engine builders, but it can be done. PS, I absolutely do not have the knowledge to be a mechanic, but I'm just going with common sense, probably a mistake. Anyway. I said my piece, Godspeed
i will take a look at that tomorrow and let you know.
someone told me a similar technique. another person said that if the rams are extended beyond operating travel they will get lodged and not want to move. the only thing to do is take them off completely and use something to squeeze it back down.
Take a long clamp bar and put it on both ends then tighten.
Moses - the reason I said buy rams is I had the same problem one year. could never get them back down and ended up the only solution was to grab two new (used) rams.
