Quote Originally Posted by mossfred View Post
Thank you guys for all your suggestions, and i have found the problem.
One injector on each throttle body was not firing. I decided to check if switching the wires on the injectors would move the problem to that injector but......as soon as i tried that they all started working!!
Now the motor runs perfectly, but i do not know why the injectors stopped or why they work again. That is the real question????
So in reality it was a fuel problem Remove the connector to each injector and clean them,,tighten up the inner part of the terminal by slightly squeezeing them and put them back on..they sometimes get a littls loose from hitting waves..
