502 engine problems
have a 502 with 550hp, watercooled headers had broken exhaust valve on rear cylinder#8 new piston new valve every thing checked out at motor shop, put back in water ran for ten min broke exaust valve rear cylinder other side now bad piston and head I am afraid to fix again could their be a problem I am not aware of could water be getting into exaust port from my headers to snap a hot valve. iron eagle heads mot built at motor shop please help.
Do you have cmi's? You are new here and the problem with them is pretty well known. You need to pressure check your headers. Mine got a crack and broke a valve. Not fun especially since it was scheduled for a check up the next day. If you have a leak go to a manifold style set up and be worry free.
502 bad valves
thanks dont know what style headers I have, big black ones on the bottom there are waterline hoses that go to the thermostat area, dont know much about howthey work, there off the boat I will take a better look at them. does the water actually mix with the exaust or is it seprate in the header
Originally Posted by 24challenger
(Post 3489812)
bad valves
thank you everyone for you input new to this chat thing going to be come a paid member. Lots of differnt sugestions on my breaking exaust valves from bad headers to bad valves, was told only exaust valve to use would a inganol valve 100 a piece the valves I have are a 30 dollar valve any sugestions on this mess i have
