need y pipe for TRS (elbows) >
Old 10-12-2011, 09:37 AM
jeff32's Avatar
Default need y pipe for TRS (elbows)
either new, or used. They are not actually Y-pipes, they are seperated elbow assembly
stbd side part number is 77117a3
port side part number is 77118a3
I found a SET A DOLLER OFFSHORE BUT STILL MISSING A SET FOR 2ND ENGINE...
Thanks for your help!
jeff32 is offline
Old 10-12-2011, 01:40 PM
14 apache's Avatar
Do they bolt to the inner transom plate with three bolts. If so i have 2 sets 150.00 plus shipping. Thanks Eric
14 apache is offline
Old 10-12-2011, 04:17 PM
jeff32's Avatar
Let me check!
jeff32 is offline
Old 10-12-2011, 05:55 PM
14 apache's Avatar
Let me check!
Just checked the part # i have them.
Old 10-12-2011, 11:26 PM
jeff32's Avatar
here is the scan of what I apparently need, do you have the bottom and top pipes?
File Type: pdf
jeff32 is offline
Old 10-13-2011, 07:08 PM
14 apache's Avatar
Jeff the only thing i have is the elbows for the transom plate. The inlet is 4".
Old 10-13-2011, 08:08 PM
jeff32's Avatar
I'll go measure in 2 or 3 days... thanks!
jeff32 is offline
Old 10-14-2011, 07:08 AM
Pwrbt33's Avatar
All we have are 2 #7's. 1 left and 1 right. Sorry.
Pwrbt33 is offline
Old 10-23-2011, 07:11 PM
jeff32's Avatar
the hole itself really is a 3 inches hole on the transom. the pipe's outside edge might be a 4 inches... did you measure the outside of pipe? or hole on transom?
jeff32 is offline
Old 10-23-2011, 07:38 PM
I have one new set of #7. I have a used set of #4 but the down angle was cut off to use the pipes for thru transom exhaust. If interested send me a PM and I'll sent you pictures of what I have.
Clustergear is offline
