Cool Article:Big Bang Theory
#61
CMI makes a nice unit but a little pricey. There are lots of cast manifolds available too. We've been using LS engines for years in aluminum jet boats up here. If you want to make your own the cheapest route is GM performance parts. They've really done a good job of keeping parts prices down to help promote the platform. The LS3 is a great starting point if you want an all aluminum engine and will make 500hp with just a cam swap. Personally I like the LSX 376 forced induction package. It's got a tougher rotating assembly and 9:1 compression. With a cam swap it'll make just a bit under 500hp but live on cheap gas. The LSX 454 was tested for 50hrs straight WOT between peak torque and peak hp without issues. If you're going to run a blower on any of the production engines with cast pistons be careful with the tune up...
Here's some out of the crate LS7's with only a cam swap. As usual I think Weismann was ahead of the curve running LS's years ago. I'd like to hear an update on his experience with them. Sounds awesome! http://www.youtube.com/watch?v=EFZP9...eature=related
08 OPA High Points Champion
#62
cool, that lsx376 is a nice piece, pricing seems go to. what whould one do for induction? My first thought was to just pick up a pair of LS3 Vette or GTO takes outs. I dont plan on anything over 500HP and would like to retain the port FI. Sounds like that shoudnt be to much a streach
#63
mostly i am looking for reliability over HP. Years ago i did a long runner TPI for a Camaro i had. Used all off the shelf stuff with the exception of a no vats chip. My thought was i was going to drive he heck out of it and wanted the ability to replace any sensor or ??? at a place like AutoZone on the weekend if need be, although i used all GM components i was looking to keep going in a pinch if i had to. Wanted to use as few mail order only type parts as possible. I even went to the length to make a custom collector to house a non heated O2 sensor so as not to need a heated one. The entire system worked like a charm and gave me thousands of trouble free miles from day one. I would like to do something similar for the LS motors. Use as many readily available Merc or GM parts as possible if i can. Would also like the ability to replace most anything using off the shelf stuff. I have no prob giving up hp for reliability in this project. In this boat 900hp is plenty for me. Is it feasible to build a system using this concept? I know the computer will need a custom burn but what FI computer would work best for what I'm trying to do? Thanks for your input.
Incidentally when i did the old school long runner TPI for my Camaro it really sold me from never building a carb system again. Really simple and easy to work on, i did mine in the mid 90's while that was still the trick set up lol. I still have an old 305 TPI engine out of a 80's Iroc i am sticking in an S-10 Blazer for fun. Easy ,cheap system to install. Funny story, i was working for a Chevy dealer when the 85 Vette came out with that system. I remember when we got the first one in i popped the hood looked at the near Area51 alien like system and said "oh my god . . . this is the end of street roding . . . how are we ever gonna work on this stuff" lol no schit
#65
That's a nice clean install on the camaro! Once someone gets over the initial fear of EFI there's no going back..
#66
Amen on the fear thing, for comparison sake i have no idea how to tune a carb yet i set up the whole long runner TPI myself in a day and pretty much never touched it again, put ten thousand trouble free miles on it before i sold it.
That sounds like a great punch list for what i want to do for LS power. I was hoping i could use the majority of factory components. Man i gotta get out'a the glass section of the tech part of the forum more often lol , keep forget'in we have a DIY. Sounds like a good thread for what i am doing
#67
you do find a killer deal on some ls3's you could swap the pistons out for a forged dished unit from Diamond or Mahle to drop the comp
I've been following this thread since day one and having the same thoughts as Glassdave. Haxby- by dishing the piston would you potentially look at having detonation issues by loosing the quench built into these engines?
#68
#69
You only need to drop about 1 point in compression so you can use a piston with a D-shaped dish with a quench pad. It's not a big deal though even with a full dish. The chambers are very efficient and detonation resistant. The 5.3 LS's come from the factory with dished pistons, as do the 350 Mag's with vortec heads.
#70
Just to keep the LS thread going.. This thing's got way too much throttle blade area and the intake is more for looks then function. I was surprised that the little LS1 is still pretty crisp though. Needs a bit more tuning and I have to set up the paddle shift, then it's time for some burnouts.. I mean road test.
The one below it is getting a twin turbo'd LS376 and a six speed. I'll take some pics as it goes together. The black one's a 550hp LS3 and 5 speed. LS fever baby!
