Radio cd/ ipod
Radio cd/ ipod
Hi,
I am looking for a marine use radio w/ cd and an ipod jack, with remote controls. What recommendations do any of you have? I also need 4 speakers, what are best; I need close to 6"
Any help would be greatly appreciated-Thanks!
Alpine 9886M head unit. The alpine Transom mount remotes aren't the best as they're wireless and thus have a bit of dealy between input and execution of commands, but the Ipod interface and the sound quality are top notch if the the top notch. Plus the RF wireless floating remote is really handy if you do allot of coving.
Polk MM Speakers, specifically the Ultra Marine or UM variants. All polk speakers are Marine rated, but the UM takes it one step further. They are very durable, sound amazing, are both UV and saltwater rated through ISO exposure tests. I've been a professional Installer for ten years, and between the three installers at my shop we have 45 years of experience. Kicker, Alpine, Jl, Clarion all make great speakers, and I have installed them all; but the Polks are just a cut above. Bazooka Probably makes my second favorite speakers, but not as attractive.
Your also gonna need at least one amp, depending on your battery situation, as well as your listening preferences(what type of music, how long etc.), and available mounting location, will determine what style of amp. Class D is more efficent, but you sacrifice a little sound quality and you pay more for a good class D. AB is gonna sound better, but use more power and take up more space.
The amps I would consider would be JL, Alpine PDXM, Polk, Kicker ZXM or IX. Again depending on where and how your boat is stored, where the equipment is mounted and how well you take care of it, Marine Head unit and amps may not be necessary; however marine speakers allways are a good idea
I run the same alpine waveform metioned above except its not the marine version. i did use all marine speakers though.
if going with the alpine BE AWARE of the model Ipod you plan to use as that unit is not compatible with ALL versions of ipods (gee ask how i know....) one of mine worked (the tiny capacity one, go figure) and my 20gb one did not. download the manual to make sure your model is compatible before buying would be my advice for whatever model hed unit you buy.
Thanks for the replys, the radio is located in the cabin area with no chance of getting dew/ or rain/ wet. Does tha tmean a regular non marine head unit would work?
I run the Alpine CDA 118M with about 5200 watts. 1 of the full digital wireless remotes and 2 of the smaller floating remotes.
Great sound. All Kickers amps, component speakers (8), and 4- 10" subs.
Good stuff......
If you want this stuff go to crutchfield.com, they stock all the stuff and were great to deal with.
Good stuff......
One thing to think about is how often do you actually use the radio on a boat? Music yes but the radio? We never listened to it. We are always on our iPod, iheart, or pandora. When installing our new set up I just installed a marine rated pre amp. They have much better eq then a radio and better output voltage so your amps aren't as hot. Just another option to consider.
