Anyone run Konrads on a cat or other 100+mph ride?
Researching reasonable drive option for a cat with 800hp and keep coming back to Konrads but you don't find much on them other than on big heavy vees.
Anyone have these on a boat running over 100mph? Or on a cat? Be curious to see how they've performed.
1 Post
Why not go with Arneson #7M's and have a super strong drive that will ad extra speed over a normal Bravo XR style drive, instead of running a drive that will weigh more, be slower than an XR (with same power) and possibly not as strong? I highly doubt a complete Konrad setup will be much cheaper than the ASD#7M. Also with the Konrad you will have to run Bravo style props, and they throw blades like mad when surfaced. It is also more than 200lbs lighter than a #6 pr. drive.
Just an opinion.
Good luck with the project.
We've got a customer with a 34' DCB cat that has enjoyed fantastic results (5 seasons zero failures) with his Konrad ACE packages/800 Teagues. The boat runs 130 at 7% slip but they are mounted somewhat deep for a cat at .5" below the hull. The present generation gear case works best below the surface.
[email protected]
715-410-0735
[email protected]
715-410-0735
1 Post
What is your budget and have you talked to Rik about what an ASD setup will cost?
1 Post
There is resale too. A 36 Skater with ASD's is a much much more attractive boat for a potential buyer than when fitted with just about any other drive out there. Of course dry #6's are nice too.
