Predator Powerboats rebuilding a Seahawk_26
Thank you, as soon as Arnaldo sends it to me, I will post.
2nd visit
http://www.predatorpowerboats.com/
just came in.
fine sanding of the deck is one of the last steps in the hull prep work.
The rotary air-driven sander is the hull specialist's best friend
v
just came in.
v
I will ask the owner if the original windshield will be returned.
Thanks for the pic. Circa 1993 .
The hull was black originally as can be seen in above pics where the trimtabs covered the original gelcoat.
2nd visit to Predator Powerboats Factory
The new dash may not allow the old windshield to be re-installed. I shall ask nevertheless
These are the final hull prep work prior to the deck being primed with gray primer.
3rd visit to Predator Powerboats Factory
The primer has been applied. Fine sanding will follow and may fill one more time. then a final primer will be applied and then the final colour.
http://predatorpowerboats.com/
Seahawk is getting a final wet sanding. And will be ready for delivery soon!
Owner opted to have original colours. Inside cockpit is painted white
A windscreen will be put up also.
