III Speedmaster props
I have a #III drive 19 spline with the longer prop shaft. The hubs on the props that are on it are 6"s. Is there a way to get the 4" hub props on it?
I've seen some guys run spacers between the prop nut and the back of the prop so they could run the short hub props on a long hub shaft, don't know who makes them but you could probably have a machine shop make something.
It should be pretty simple to build a couple spacers.
Shouldn't we be able to just make a spacer to go between the nut and the prop? What does the thrust washer look like? Been a while since I've payed any attention to a SSM...
