No water psi?
No water psi?
Drove a 2006 velocity 390 yesterday. Stagered merc 525 efi with xr drives and 6 blade herring props. Boat was flawless except for no water pressure registering on either gauge. No temp issues whatsoever, is this a impeller issue or someone has suggested it is a small clogged hose?
Charter Member #1171
Probably not hooked up
Factory engines?
Factory engines?
I want to live in a world where a chicken can cross the road and not have its motives questioned.
Clogged on both motors?
possible I guess,,,,, boat have sea strainers???
the 525 pulls water pressure off the cooler on the back of the motor for the guage if it has it,,,,look for a hose there,,,,should be in a fitting with a temp send unit on it also.
