If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
  1. #11
    Platinum Member Platinum Member Twin O/B Sonic's Avatar
    My Boats:
    '88 32' Marinette seadan, bridge
    Join Date
    Mar 2002
    Clarksville (Cincy) Ohio
    Couple of tricks I've learned.
    #1. on non your platform how you want it, tape off what you don't want non skidded, mix sand w/the gel as Rick said and roll it on. Easy to do and looks great.
    #2. I have a 7' glass door I use for smooth finishes. 3 coats of wax and start spraying. The finished product will pull right off the door and have a perfect mirror finish.
    #3. There is a type of particle board (like plywood) that has a plastic vaneer on it that also makes great, basic molds. It has a slight texture though so you'll have to sand it out then you pull your part if you want smooth. Home Depot sells it too.
    #4. Remember if building a mold w/sides to design in what's called "draft" so your part will release. You don't want any true 90* walls unless you plan to destroy your mold to pull your part which is fine if a one time deal. Most use 2* as a rule.
    #5. If you thin it properly, a $10. Harbor Freight spray gun works just fine for gel.
    #6. When learning to glass, especially up north w/changing climate the biggest challenge is getting your catalyst to resin ratio correct. Buy one of the graduated squeeze bottles for the catalyst. Works awesome and eliminates guess work.
    As far as material, 1708 or something similar is great suff. It is a double laminate w/one side being mat (forms/bonds to almost everything) and the other being cloth which gives your strength.
    As for core, I'd use multiple layers of foam w/varying density. If you plan to have much curve in the main surface you'll want lower density thinner pieces. In your highly loaded areas and where you'll be fastening to you'll need very dense/heavy foam to be able to hold a screw.
    Many great books w/all the help you'll need.
    Here is the mold I made for the 7' lid on my sun lounge. Four layers of 1/4" foam w/cloth between each layer. The lid can be seen leaning against the wall to the left. I built this mold w/the particle board from Home Depot.
    Finished product.
    Balsa cored swim platform/set back bracket after repair. They gray is non skid formed from the sand mixture applied w/a roller. Really easy, cheap and looks like a million bucks.
    I'd rather be competitive w/junk I built in the garage than win w/stuff I bought.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2016 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
Original Poster In Postbit provided by Original Poster In Postbit v1.0.0 (Free) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.
