Gafrig/Livorsi....Ripoff!
Tried to order a GPS Ant. for speedo....$270 !!!!!!! what a rip-off
I dont mind paying for stuff but........Dont need to RAPE me!!!! Any-one have any ideas what else i can do??? Dont want to pitch it but ill be damned if ill pay that!!!! |
I could be wrong but i'm quite sure the GPS receiver is in the antenna on Gaffrig speedos...that is why it is that expensive.
Ted |
Yea.....Maybe......but You can buy a Garmin that does everything but pick youre nose for way less than that....
Am i missing something here?? |
Buy the Garmin for WAY less....what are you trying to do, find someone who agrees with you so you can post your *****? Gaffrig is high quality equipment that costs a few more bucks, try Nordskog, probably same price range, or go to Sears and see what they have in your price range.
Youre sarcasm is wonderful Bluemoon!:D
What i am trying to do here is find out if there is another solution and vent my frustration!!! I was hoping maybe something else might work? or maybe someone has one for whatever reason. B.T.W. Tried Sears & Kmart.......No Go;) |
Birddog,
There is a site called gpscity or gpsstore or something like that, I purchased an external ant for a Garmin 12 for $60. It seems to work just fine. If the Speedo has a place for an external ant, you could contact one of these places and see what they have. There are several types of connectors that plug into the differnet units. Not sure how the speedos are set up.. Good luck Dick |
I used a handheld Garmin GPS to feed my speedo. Some GPSs have a data output lead that will connect to the data input lead of the speedo. I can unplug my handheld GPS and use elsewhere if I want, i.e. speed check on other boats.
Thanks guys!
Mr. Gadgets: Ill start searching! rbtnt: Where is Galena Oh. ? |
About 10 miles north of Columbus. I posted some info on your other post.
I have been flipping back & forth between the two posts. Some people only check one section.
Do you ever boat down here on the Ohio? |
