| OSO Sponsor |
| OSO Sponsor |
06-26-2002, 04:01 PM
71 Donzi '21 Classic
CMI headers vs. Stainless Marine Gen III
Fellas,
I read the pro's and con's of headers vs. manifolds, each has it's benefits and drawbacks.
I'm in process of installing a 509ci BBC with radical roller cam and 10:1 compression. With that said, I could use the cylinder scavenging benefits of a full 32" runner. Stainless Marine makes a (in my opinion) a bullet proof Gen. III manifold, riser and stainless tail pipe, however the 15" runner scares me. Is it worth spending a little extra $$ for CMI's 32" runner header? (and yes, I know the headers look kick a$$ and probably sound a little better)
My friend has the GEN III's on his Falcon, and they have worked flawlessly.
Oh yeah, the boat is a 1971 Donzi GT (looks like a Classic, but is beamier) and will utilize Arneson's extension box and #6 drive in salt water.
06-26-2002, 04:05 PM
Charter Member #319
If you have the $$$$$ go with the CMI. Just got them on my boat. They do look KICK ASS !!!!!!!!
06-26-2002, 04:13 PM
2006 Hustler 388, 2000 Nordic 35' Flame and 2007 21' hydrostream voyager w/ Merc. 225 EFI
Looks aside, The KE Manifold/header is by far the best HEADER, (Full 32" runners) and is manifold TOUGH, (No leaks!) on the market. I have run my set on my HP500 for 4+ years in the Atlantic ocean and have no problems. Plus, I don't have the H2O reversion problem either with my KE's! The only down side is they are not the eye-candy that some people perfer, and they are alittle loud! I put Shotgun III's mufflers on them also, again, with no problems.
Hope this helps,
MD
06-26-2002, 04:19 PM
I can't vouch for Stainless Marine, but I will say that CMI has been nothing but helpful in setting up my exhaust. Got the wrong tailpipes (my fault), no problem, had custom ones made in a week and 1/2 - a perfect fit. I couldn't measure from the outside of the boat for custom tailpipes (Formula with Silent thunder platform), so they helped me figure out dimensions from the inside. Tore a header gasket adjusting rockers, no problem, overnighted me a new pair. They've been great.
Just my experiance.
Scott
06-26-2002, 08:22 PM
Charter/Platinum Member
2006 American Offshore 26'
Tried both types on my naturally aspirated full roller, 10:1 compression, 588inch tall deck. The Gen III pulled 5 more HP above 5,000. The CMI's are prettier, but the Gen III's work, besides, Iam starting my 4th boating season, and they still look brand new.
06-26-2002, 09:16 PM
2001 Donzi 26Zx
Nate...
Do the rest of your Donzi brothers know what you are up to?? Good thing I'm putting a 'Hawk on mine. I'll need to just to keep up!!
Woodsy
06-26-2002, 09:28 PM
Registered User
Fast Boats (surprised ?)
CMI all the way. I bought a set with the "cool collars" and they perform flawlessly. Also I found out a trick that makes them last years longer in salt water apps. On the runner, remove the rear cap and replace them with an adapter and a 1/4 inch hose. Run the hose out of the hull just above the water line thus allowing them to drain automatically after each use. I also think the CMI's have a lifetime time warrenty. Otto
06-26-2002, 10:30 PM
Pat at Active Thunder is putting CMI on my KE675's, I have them also on my Sonic, never have had a problem, 88 hours and no leaks.
06-26-2002, 11:14 PM
Troutly, You can see your reflection in them, eye candy it is.
06-27-2002, 08:17 AM
Troutly,
I'm just an "Enginerd" by trade/schooling, therefore I make most of buying decisions based on performance/reliability data, (Enginerd's curse!), just like @ work! It's funny, when I look @ KE's headers, I see a BEAUTIFUL example of ENGINEERING/DESIGN and reliability, but, hey thats' the curse I mentioned earlier.
I would like my next set(s)? of KE headers to be coated the Mercury Racing Blue, if he can do that? I wonder if KE will polish them, that would improve the "Eye Candy factor"? Hmmmm?
MD
