PSD drive train questions
Old 06-24-2002, 06:50 PM
Default PSD drive train questions
Is there a simple way to determine final gear ratio in a used PSD?
For example, with stock size tires, XXXX RPMs at YY MPH equals Z.ZZ drive ratio.
Secondarly, is a shorter ratio harder on the drive train than a taller ratio? (I've thought about this, and can think of good arguments for both sides).
Thanx.
Chart is offline
Old 06-26-2002, 12:50 PM
ttt
Chart is offline
Old 06-26-2002, 12:57 PM
SeaDated's Avatar
Try thisrive Train
Final Drive Ratio Computation
The formula is:
Final ratio = (Tire Diameter in Inches x RPM) / (336 x MPH)
SeaDated is offline
Old 06-26-2002, 01:39 PM
ccarloss's Avatar
2000 PSD 4X4 automatic w/3:73 rear turns approx 2050RPM's at 70MPH with 265/75/16 tires.
I believe the 4:10's turn about 2300-2350 @ 70MPH
ccarloss is offline
Old 06-26-2002, 01:44 PM
Thanks guys.
Does the drive train have more stress (likelyhood of breaking) with the shorter ratio than the taller ratio, pulling a load?
Chart is offline
Old 06-26-2002, 01:56 PM
Charter Member #232
Audiofn's Avatar
You can take the Vin # and call the dealer they will be able to tell ya from that. What is your concern? I think that your boat is not going to put any stress on that truck what so ever. I pull mine and I keep looking back to see if it is still there. Curts Cig that was substantially heavier then our 302's you could tell was back there but it would hold 70-75 no problem and averaged about 12-13mpg all the way home
Put your best foot forward!
Audiofn is offline
Old 06-26-2002, 03:09 PM
Jon: Concern is a strong word; it is more an interest. After using what little gray matter I have on a ponder, I hate to leave it unresolved. Our 10-12,000 lb loads wont challenge either one, heck I pull it now with a stock-drivetrain half-ton burban. (Yes, the breaks and suspension are beefed up on it).
So, do the individial teeth on the gears in a drive train have more stress applied with a short final ratio than a tall ratio, or is it the same.
After all the time we spent on "which freezes faster: hot or cold water?", there should be some good insight on the gear question.
Chart is offline
Old 06-26-2002, 06:00 PM
Charter Member #232
Audiofn's Avatar
I am going to say that there is less stress on the drive trail with shorter gears. IE causing your RPM's to be higher on the highway. The axle I would think is under more stress however.
Jon
Audiofn is offline
long duck dong
Drives and Lower Units
6
11-24-2007 06:35 PM
hpy540
0
07-27-2007 12:13 PM
FormulaM2Formula
06-11-2006 01:19 PM
Raypanic
5
06-10-2003 11:38 AM
tomcat
1
01-25-2002 11:21 PM
Quick Reply: PSD drive train questions
