What Prop+Prop Pitch on 24' Superboat?
I just want to make sure I'm getting the right prop. I have a 2000 24' Superboat.
I've been told a Trophy Plus is the best one to get? Not sure what pitch tho.
Motor is a 225 Promax with rebuilt lower unit(2.1 gear ratio) and my current prop is a Michigan Wheel Apollo 22 pitch. Hitting 6000 rpms at wot
Looking for top speed
Id stick to your threads on S&F vs here due to the fact that that is an outboard oriented forum, and im sure at least 5 people on there have had the exact same setup on that hull. But try merc mirage plus 22p. go from there. stick with merc props and then test from that platform. you an going to get a million opinions, just go to a shop and borrow a prop for the weekend and return it. lots of shops have demo props you can use.
