what means 5 consecutive beep alarm on 525?
redid the bilge paint and dropped a refreshed engine at same time... first sea trial, i could hear 5 consecutive beep of 2 seconds each, and then, exactly 60 seconds after, the 5 same beeps were back again.
Every single gauge showed perfect, boat ran A-1, I shut down all engines after 15 minutes of those beep, started them all again, and never heard those beep again...
anyone knows what those beeps meant?
low drive fluid?
The book says it can be one of four things:
1. MAP Sensor Error
2. Coil Pack Failure
3. Fuel Injector Failure
4. Fuel Pump Failure
None of these will put the engine in Guardian Mode. It says if it stops beeping on restart it doesn't require immediate attention but should be checked out on the computer to see what the default was and clear the fault.
1. MAP Sensor Error
