switzer ss240 questuions
could also be overtrimming if you say you trim all the way up....have you tried going up then a touch back down?
Smelling fuel does not sound normal either.
Good luck either way, lots of knowledge on this site to help you out
I have done a tune up,,, but have not changed the fuel filter. Would this be a issue.. unwilling probly change that this weekend then.. the guy at a local marina told me not to change the wires if its running ok,,so I did not ,,just plugs and oil I did... So change the filter as well... Idk if this is a dumb question buy my prop is corroded should clean and shine this up again..
If the boat is turning the RPMS an running right look at the boat an prop. Get someone to take a picture of the boat running trimed up w.o.t an post a picture. Let us see whats going on an the R.P.S at the time of the picture. I really think Your draging the boat. Heavy with water or trim. Pictures will help us. Artie
1 Post
fixx
im wondweing if the fuel smell is coming from the fuel being traped under the floor and the foam is holding it back from leaking..find the fuel smell first and where its coming from before the boat exploads and you kill someone..now that you let it be known on a public forum its most likely nation wide and if something were to happen in the near future its known here and where ever this webbsite's server is linked to...
I'm gunna pull the floor next week,, thanx for the concern.. I will keep u guys posted.. I know the floor was replaced 2 years ago and looks good.,, but I still want to check under there too see, since u said something.. I will be trying everything y guys say till I make it right.. because I know its def not at its potential speed.. any other things I should explore or check?? It's greatly appreciated guys!!
