Can a Mirage (non plus) prop be converted to solid hub?
Is there anybody that can convert a standard Mirage (non Plus) prop to a solid hub? If so, can you let me know who can do it?
1 Post
fixx
http://www.wholesalemarine.com/p/835...835258K-2.html
Thanks for the replys. I think I may need it welded.... This prop I have has a round style hub (not square like that torque flight, I have that set-up on another prop).
So I guess I am looking for a round style solid hub for a mirage prop.
The prop I have that is in question is a Mirage 3 blade 25P standard rotation (single engine).
My engine makes 610 HP. I normally run a 4 blade with the solid hub and its great. I was also given this 3 blade with the boat, but it has a regular Rubber/Nylon hub and spins when you get on it hard.
