IMCO SCX Drive Replacement?
I am curious how many hours you ran to reach those miles
That's cool, I can remember when I first started boating I didn't know if 200 hrs was a good or bad thing, being so used to everything else using miles. Now I read your "miles" and I don't know what the hell they mean!
I have a boat that runs over 100, & a friend's who runs just under 100. He aways running faster then I am and I bet the wear and tear on his motors and drives is way more then mine with both having the same hrs or miles.
arneson-industries.com
Offshoreonly Advertiser
It's not an IMCO but the 39' Cig runs really well with Arnesons! You won't loose speed, nor have to speed a ton of time with spacers and you will have a warranty.
Arneson Surface Drives www.arneson-industries.com
Pat
I just got the scx put on
Changed from 32 to 32 labbed props
Boat gets on plane much easier also steering feels tighter for some reason
Couldn't check top end since there is speed limit at lake and the po po was following me
But will have more info after this weekend in destin ( how's that for a test run )
Rik I would be interested to know the gains in this setup with equal power. I have looked at several 39's and cannot justify the price difference in the 700/NXT set up.
Pat
Thanks Pat
